Basically one full turn on the nut is 360 degrees, soooo 160 degrees is 20 degrees less than one half turn on the nut. So do the first pass to 15lbft, then turn it a little less than 1/2 a turn and finish with the torque wrench to 33lbft.
As I remember, the tie rod end will spin in the knuckle, I wonder if it means to rotate it within the knuckle prior to final tightening. It can't mean stretch the threads that much.
I'm still confused.....Not sure what the purpose is of turning the nut 160 degrees. Seems I can just keep torqueing from 15 to 33 lb ft and this will rotate the nut 160 unto itself!?!?!?!?
This was confusing to me too because the manual don't explain this at all. I was just in this the night before last. I "think" from seeing other things like this in the manual it means:
1. Torque the nut to 15 foot pounds.
2. Turn the nut 160 degrees. (the theory here is 160 degrees will pull the tie rod end up into the aluminum knuckle expanding the aluminum an exact amount that GM engineers has determined to be the best)
3. Torque to 33 foot pounds. (After step two the nut should already be tighter than 33 foot pounds and should not turn any more, this is just to check to be sure it is tight enough, like if the stud was not seated well and slipped while turning the 160 degrees it wouldn't be 33 foot pounds yet)
As soon as you get past 0 torque (like 1/2 foot pound) the stud will lock in the knuckle and not turn anymore, you no longer have to hold it with a allen wrench.
Now I'm further confused.....I've bought the VBP ends and there's no place to use an allen wrench anywhere on them? Never thought it would be this difficult......Anyone else know the answer?
