C5 wheels on a C4? Possible?
Old Mar 16, 2006 | 06:44 PM
servohead's Avatar
servohead
Default C5 wheels on a C4? Possible?
Hey guys,
I may be selling some C5 rims to a guy with a C4 and we were both wondering if the offset will be correct? His C4 has 16" wheels all around and also worries if he puts 275's and 245's on it that they'll cause interference..... Anyone tried this?
Old Mar 16, 2006 | 06:48 PM
lar66BB's Avatar
lar66BB
Default wheels
Yes no problems.
Old Mar 16, 2006 | 08:45 PM
lloyd's Avatar
lloyd
Default Offset?
If his car has 16" wheels chances are it is a 1984 thru 1987. If that is the case the offset is very wrong for that car and for it to look right he will need spacers.
Old Mar 16, 2006 | 09:57 PM
servohead's Avatar
servohead
Ok. You're exactly correct two, his is an '84... Kind of a sad rig, but he want's C5 rims on it! If spacers'll do it then maybe he'll go for it. Thank you for your help.
Old Mar 17, 2006 | 03:36 AM
JETZ's Avatar
JETZ
Well on this one they do!
Old Mar 17, 2006 | 10:31 AM
servohead's Avatar
servohead
Cool! Did you have to use spacers?
Old Mar 17, 2006 | 08:27 PM
JETZ's Avatar
JETZ
I just found this pic, so I don't know.
Old Mar 17, 2006 | 09:36 PM
MYCoupe's Avatar
MYCoupe
On the 84-87 you will need 1-1.25" adapters. On the 88-96 they will bolt right up.
Old Mar 17, 2006 | 09:56 PM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
Worked on my '96...
Old Mar 30, 2006 | 08:01 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If using 1" adapters, check and make sure the stock lugs that stick through don't interfere with the wheel mounting surface.
Old Mar 30, 2006 | 09:39 PM
QuikZilver's Avatar
QuikZilver
88+...no adapters needed
84-87...adapters needed (See Admiral94's post)
Old Mar 31, 2006 | 09:13 AM
J-Rod's Avatar
J-Rod
Correct. In 88 they revised the suspension.
If you look, this is why 84 Corvette suspensions are desirable for many of the Pro-touring donor cars they have anrrower track width, etc...
88 and later is fine. Before that needs spacers.
To C5 wheels on a C4? Possible?
