Daytime Running Lights?
Old Mar 16, 2006 | 08:06 PM
VETTING's Avatar
VETTING
Default Daytime Running Lights?
How do you disable the "daytime running lights" on an 04 C5 without affecting the signal funtion???? Thanx
Old Mar 16, 2006 | 08:14 PM
Blowtorch's Avatar
Blowtorch
I have been told (but never tried) that if you pull up the parking brake one click, they will go out and it doesn't engage the brake.
Old Mar 16, 2006 | 09:16 PM
DoubleZ06's Avatar
DoubleZ06
I tried the one click up on the e-brake and it doesn't shut mine off. Oh well.
Old Mar 16, 2006 | 09:30 PM
birch64's Avatar
birch64
i tried that also, no luck.........
Old Mar 16, 2006 | 09:36 PM
1-BAD-VETTE's Avatar
1-BAD-VETTE
Pull the #2 fuse under the hood, done deal. No effect to the turn signals. only thing affected is the lights won't flash on approach.
Old Mar 16, 2006 | 10:59 PM
ALLEGRO's Avatar
ALLEGRO
OK here goes:
If you pull the #2 fuse you will LOSE some of the APPROACH features.
This is easy...I promise !
1. In the passenger footwell, lower the front carpet.
2. Remove the foot panel.
3. Locate the IPEC (Instument Panel Electrical Center) It looks like the fuse box next to the battery.
4. Remove the cover of the IPEC.
5. Turn it over and find the diagram of the components.
6. Locate relays 38 and 40. (38 controls the right DRL and 40 the left)
7. Pull each relay and carefully remove the cover.
8. Insert some type of insulator between the relay contacts (matchbook cover cardboard or the plastic from a coffee can lid works well) that you have cut to fit.
9. Replace relay cover, replace relay, replace IPEC cover, replace the footwell.
10. DONE!!
You will now have NO drl's and retain ALL of your APPROACH features. I have had mine this way for over three years and have had not a prob. Good luck and feel free to PM mewith any question you might have.
Old Mar 17, 2006 | 08:59 AM
jedicowboy's Avatar
jedicowboy
Yeah that is BS. Funny how it always keeps popping up in the "Did you know?" list
Old Mar 17, 2006 | 04:39 PM
FKING1's Avatar
FKING1
allegro,
Thanks much for the good tip. I will put my number 2 fuze back in and follow your directions.
This Forum rocks.
Fred
Old Mar 17, 2006 | 08:21 PM
VETTING's Avatar
VETTING
Thanks for the input. I think I might go with de-energizing (pull the fuse) the circut. It only seems to affect the flash on lock feature for me. I've never used the approach light option on the DIC...
Old Mar 17, 2006 | 09:00 PM
Kennysvette's Avatar
Kennysvette
pulling the e-brake doesn't shut them off, but if you have it up one click before starting it they wont come on. your lights wont come on either, though.
Old Apr 7, 2006 | 06:23 AM
revtex's Avatar
revtex
Would this procedure also apply to the C6 ? and does it affect the turn signals
Old Apr 7, 2006 | 10:20 AM
clemsondave's Avatar
clemsondave
Old Apr 7, 2006 | 11:09 AM
rwsr50's Avatar
rwsr50
Originally Posted by allegro
OK here goes:
10. DONE!!
So what would happen if you just removed those two relays rather than insulating the contacts?
Old Apr 7, 2006 | 03:35 PM
Dirty Howie's Avatar
Dirty Howie
I have #2 fuse pulled.
What is this "Approach Feature" that you guys are referring to ??
DH
Old Apr 7, 2006 | 07:35 PM
DirteeDave's Avatar
DirteeDave
DH
The reverse lights don't flash when you lock/unlock the car.
Old Apr 7, 2006 | 09:00 PM
rwsr50's Avatar
rwsr50
If you have the Approach Lights selected in the DIC, when you approach the car and unlock it with your remote, the lights come on...but only under low light/dark conditions.
Old Apr 8, 2006 | 12:49 AM
Dirty Howie
My lights flash and stay on till I open the door and I have #2 fuse pulled!!
DH
To Daytime Running Lights?
Old Apr 8, 2006 | 02:10 AM
roddog's Avatar
roddog
i have another daytime light question, on of mine is out, the you replace it from behind or pull out the lens?
Old Apr 8, 2006 | 04:08 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
DH
I just pulled my #2 fuse and was done with it.
Old Apr 8, 2006 | 02:19 PM
roddog's Avatar
roddog
anyone?
