450rwhp?
Old Mar 17, 2006 | 05:30 AM
c45's Avatar
c45
Default 450rwhp?
is it hard to get 450rwhp with out f/i? i want something that is as reliable as possible since it will be my primary car. i have a 99 vert with a m6. i was thinking a ls6 intake lg lt's cam and callaway honker, what else would i need to reach my goal?
Old Mar 17, 2006 | 05:52 AM
torchvette10's Avatar
torchvette10
Hi,
a good head and cam package would do the trick. LG has some great packages. You should contact them. Also add a set of LT headers and a good flowing exhaust and you are good to go.
Old Mar 17, 2006 | 07:59 AM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
heads, cam, intake, headers.
Old Mar 17, 2006 | 08:04 AM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
Been there done that. I would not get too overwhelmed by the dyno numbers, esp peak, but look at the power below the curve and the torq. My car only does 460 :o but makes much more HP and torq below 6k, where the 470 cars peak and pass me by. Me learning to drive it after my H/C swap ummm
BLUFF, it can be done quiet easliy, and a H/C car is a blast! Nice agresive idle, pulls like a tank and it is still a great car to drive around in, and no worries about belts, leaning out on top with changes in the wheather ect... I was going the FI route untill I was cam only (small blower cam). Once I drove it with the idle and the way it pulled, I was hooked. Go for it brother
Dave
Old Mar 17, 2006 | 08:06 AM
Shane_S's Avatar
Shane_S
you'll be into it for about $6000 to get a NA car to 450rwhp, thats including the cam, heads, Fast 90 setup, headers, and a few other bells & whistles. And that is if you can install it yourself.
Shane
Old Mar 17, 2006 | 08:17 AM
402Sam's Avatar
402Sam
See sig, very conservative tune for nitrous. If you keep the car N/A then you can bump up the timing and make close to 460rwhp.
Old Mar 17, 2006 | 10:00 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Old Mar 17, 2006 | 12:10 PM
Casem1's Avatar
Casem1
Cubic Inches
Old Mar 17, 2006 | 12:27 PM
Mr. Jones's Avatar
Mr. Jones
when you say reliable 450rwhp, you start with big Cubic Inch.
now the valve train can be a little easier to maintain.
torque and hp will be there with a dart sleeved block, good heads and a suitable cam.
Old Mar 17, 2006 | 02:47 PM
Face's Avatar
Face
A good set of heads and a big cam should do it on a MN6.
Old Mar 17, 2006 | 02:57 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
On an LS1 you cannot get 450 without H/C combo
Old Mar 17, 2006 | 03:59 PM
Nukecop's Avatar
Nukecop
St. Jude Donor '05
how bout an A4?
Old Mar 17, 2006 | 04:02 PM
shakainc's Avatar
shakainc
I like the Cubic Inches idea. 427 sounds good.
Old Mar 17, 2006 | 05:07 PM
c45's Avatar
c45
ya it does. i have been looking and if i can find a short block in good shape cheap i might just go that route. get the block order ls6 intake, heads and cam. the main thing is the a$$holes in CA are pretty strick on smog so i can't have a huge cam. plus if i go this route i'll have a extra block just in case right?
thanks for the info guys
Old Mar 17, 2006 | 10:56 PM
mcv's Avatar
mcv
I think the LS1 heads are your limiting component, even with considerable porting. With 346 cid, you'll need better heads and a very aggressive cam profile. You already know you need Honker, long tube headers (non-emissions-compliant), and an efficient cat-back system. And then 450 at the wheels is still going to be tough to achieve. Plus, the torque curve is not going to be very flat. Personally, for what it's worth, I don't think this is a combination that would work well as an everyday, "primary car".
At Callaway, the only way we've been able to accomplish this level of performance in a reliable, streetable package is either with our 7.0L/427 cid SuperNatural 550 or with our new SuperCharged 560 Corvette.
Old Mar 19, 2006 | 10:01 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I made 447rwhp, and 427rwtq with LG's G5X1-E cam/AFR 205's 59cc, LG Pro Long Tubes with cats. VERY close to stock drivability I am finding ! E stands for Executive, or emissions since this cam can pass Texas Emissions if ever required..... Not required at this time though.
Check out my video :
http://mysite.verizon.net/res0aae8/z...aminstall.mpeg
My web site for mods:
http://mysite.verizon.net/res0aae8/webpage.html
Let me know if you have any questions.
Yes.... I would do this again
Toque
Old Mar 19, 2006 | 10:04 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I opted to just get blown and stay with a conservative tune...
To 450rwhp?
Old Mar 19, 2006 | 10:09 AM
turboed's Avatar
turboed
so if ls1 heads are a limiting component,what heads are most using here?
Old Mar 19, 2006 | 12:27 PM
mean lx's Avatar
mean lx
Toque
Sounds sweet! What are the specs of the cam (duration@ 0.050 and lift, LSA)? Were those figures with a tune and any track times? Thanks, James
Old Mar 19, 2006 | 01:16 PM
Toque's Avatar
Toque
Thanks James
Yes the RWHP, and RWTQ were with a tune. I have not had time to track my car. One day once my son gets a bit older I hope to have the time though
LG's seems to hold the specs of this cam close to there heart... contact Lou for details.
Toque
