Clearing DIC codes
Old Mar 17, 2006 | 08:19 AM
tommybilt's Avatar
tommybilt
Default Clearing DIC codes
I have about 12 history codes popping up. If I clear them will they no longer pop up if there is a problem?
Old Mar 17, 2006 | 08:36 AM
BrentNY's Avatar
BrentNY
Youre OK. If they show up again it will show C for current and probably as a History code to.
Old Mar 17, 2006 | 10:09 AM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
You can go ahead and clear them...
If the same problem occurs again, they WILL indeed reappear...
I think that's what you were asking correct?
Old Mar 17, 2006 | 04:03 PM
aj98's Avatar
aj98
Or if you are so inclined, you can just ignore them.
They'll disappear on their own after....40...ignition key cycles (w/o a repeat of the problem.)
AJ
To Clearing DIC codes
