Change lifters??
Old Mar 18, 2006 | 08:14 AM
DoubleZ06's Avatar
DoubleZ06
Default Change lifters??
I am about to swap out my cam and bought the valve package which contains the upgraded springs, hardened push-rods, Ti retainers and new locks. Do I need to change the lifters? I've heard the stock GM lifters are quite durable and strong enough for upgrades. Anyone agree or disagree??
Old Mar 18, 2006 | 09:24 AM
GOOSE JR.'s Avatar
GOOSE JR.
The stock lifters are preety good. I asked several shops about the stock lifters and they all said to use them.
Old Mar 18, 2006 | 04:09 PM
DoubleZ06's Avatar
DoubleZ06
Thanks- anyone alse???
Old Mar 18, 2006 | 05:23 PM
vettenuts's Avatar
vettenuts
You can only change them if you pull the heads, from the sounds of your plans it doesn't sound like you are. Make sure you take precautions so they don't fall while you swap out the cam.
Old Mar 18, 2006 | 07:01 PM
greg_nate's Avatar
greg_nate
If I were to do it again, I'd change the lifters. Then again, I put a fairly aggressive cam in my motor, which I think stresses the lifters more than a mild cam upgrade.
So why would I change lifters? I've had lifter noise, that drives me batty. I'ver been told by many people that as long as it doesn't get too bad, I am fairly safe. Still though, I don't feel all that comfortable driving around with that kinda noise coming from the engine. Next round of engine mods, and the stock lifters are coming out. In fact, that may be the only mod.
Old Mar 18, 2006 | 07:11 PM
Av8terZ06's Avatar
Av8terZ06
Your stock lifters will be fine. You really dont even need the hardened pushrods.
Old Mar 18, 2006 | 07:14 PM
SilverC5Vert's Avatar
SilverC5Vert
Depending on how many miles your car has and as greg_nate said depending on how aggressive of a cam you use, you may want to swap them out for a new set. I had some lifter noise and replaced mine with a set of new factory lifters and it's quiet as can be.
-Rick
To Change lifters??
