CK Engine light and code P0133
Old Mar 18, 2006 | 10:29 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Default CK Engine light and code P0133
I checked it and it said "heated Oxygen Sensor Slow responce bank 1 sensor 1" Anybody know what would cause this??
Old Mar 18, 2006 | 10:47 AM
yogi78's Avatar
yogi78
It could be just a dirty or loose connection on the O2 sensor wire. Or it could be a bad O2 sensor. I think the O2 sensor has an electric heater element in it so that the engine can use more efficient/ emission friendly mixture settings when the vehicle is cold instead of having the wait for the O2 sensor to be fully heated by just the exhaust stream. I would check to make sure the connections are clean and reset the code, it may never come back. If you have a scan tool there is a whole procedure to check the voltage to the O2 sensor.
Old Mar 18, 2006 | 10:52 AM
mvvette97's Avatar
mvvette97
I cleared the codes lastnight so i will go out and check the connection to see if it dirty or loose. Thanks.
Old Mar 18, 2006 | 07:30 PM
lloyd's Avatar
lloyd
Default L/F O2 Sensor
probably a failing left front sensor
To CK Engine light and code P0133
