Need Help Diagnosing a Problem
Old Mar 18, 2006 | 01:57 PM
MagRedSkull's Avatar
MagRedSkull
Default Need Help Diagnosing a Problem
The revs drop too low (about 400 or 300 RPM) & the car feels like it is about to stall (but it does not) when applying brakes just before coming to a stop. The revs come back up to about 600 RPM after I am stopped. It does this every time I come to a stop.
Some of the things I have done, that did not help, are; changed plug wires (MSD), changed spark plugs (NGK), PCM tune (LAPD), replaced the fuel filter, added a Blackwing, use Chevron gas exclusively, and have added bottles of Techron injector cleaner to a tanks of gas occasionally. The car has always idled rough since I bought it new. I have had this problem for a long time, but it seems to be getting a little worse or maybe it is just bugging me more.
What else should be checked?
Old Mar 18, 2006 | 02:07 PM
dpd's Avatar
dpd
clean out the throttle housing.you don't have enough air coming across the blade because it's all gunked up.
Old Mar 18, 2006 | 04:47 PM
VetteTech81's Avatar
VetteTech81
I would check this first..
Old Mar 18, 2006 | 09:20 PM
ALLEGRO's Avatar
ALLEGRO
Here's a stretch.....
You may have brake-booster issues with vacuum. They can really dump a lot of vacumm from the resevoirs when you hit the brakes.
Probably not your issue, again just a stretch.
Old Mar 18, 2006 | 09:56 PM
C5Jim's Avatar
C5Jim
This is the best place to start especially if the service has not been done before.
Next thing to look at is the idle air valve. These have a tendancy to gunt up over time.
Good luck.
Old Mar 19, 2006 | 11:58 AM
MagRedSkull
Thanks for all of the suggestions. This forum has a lot of great people that will help and share their knowledge.
Old Mar 20, 2006 | 08:33 AM
9secondflat's Avatar
9secondflat
i think i have your answer, my car ran fine- i only owned it for 3 months. two weeks ago i took it out and every stop light/stop sign the car would go from 1k rpm down to 400-500 and than crap out. to say the least it was bothering the hell out of me. i noticed during this incident (it lasted the entire time i was out- about 15miles) my volts were around 13.6-13.8 , it was very cold outside around 20 degrees but i had run the car in close to zero weeks earlier with out any problems. this past weekend i took the car out and wada think i saw... my volts were 14.3-14.5 and not a single time did the car stall! my guess is the car needs a minimum amount of volts to have the computer function correctly....any tech guys chime in....\
take a look at your volts if they are in the 13.6 range i bet this is your problem. now the question is..... is it the battery getting ready to take a crap.... or does the car have a volt regulator/altinator ready to go south...... my .02
To Need Help Diagnosing a Problem
