Having key fob problem
Old Mar 19, 2006 | 11:50 AM
Bud8's Avatar
Bud8
Default Having key fob problem
I disconnected my battery to do cleaning and when I hooked the battery back up my key fob does not work. Is there a way to reprogram it to work again. Thank you
Old Mar 19, 2006 | 12:13 PM
Vettegetsmwet99's Avatar
Vettegetsmwet99
Fob programming
1-Turn the ignition to RUN
2-Turn the radio off
3-Press the RESET button in order to clear any IPC warning messages
4-Press the Option button on the DIC until the IPC display is blank in order to enter the program mode
5-Press and hold the Reset button for 3 seconds
6-Press the option button until FOB Training message is displayed
7-Press the Reset button in order to begin the programming sequence.
8-Simultaneously press and hold the lock an unlock buttons on the first transmitter for 12 seconds. The IPC will indicate when that transmitter is programmed and when to proceed to the next .Repeat this step for each transmitter.
Old Mar 19, 2006 | 12:25 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
On my 98 if I disconnect the battery I can reprogram my remote using the short version. Hold down the lock and unlock buttons simultaneously for approximately 10 seconds until the horn beeps. If that doesn't do it then try the long version that Vettegetsmwet99 gave you.
Old Mar 19, 2006 | 12:29 PM
Bud8's Avatar
Bud8
Vettegetsmwet99 & RocknRoll Thank you for the help it works.
To Having key fob problem
