check engine light HELP!
Old Mar 20, 2006 | 05:04 PM
happa's Avatar
happa
Default check engine light HELP!
My check engine light just came on. The code it had as current is 10-PCM P1133. Its the heated Oxygen Sensor (HO2S). Where is it and what exactly is the heated oxygen sensor? Thanks for the help.
Old Mar 20, 2006 | 05:15 PM
dpd's Avatar
dpd
the fault is for insufficent switching bank 1[left] sensor 1[front].you most likely need the front sensor.the heater is no getting hot enough
Old Mar 20, 2006 | 05:23 PM
happa's Avatar
happa
Is that my 02 sensor for my cats? And exactly where in the front? Thanks for the help man!
Old Mar 20, 2006 | 05:28 PM
dpd's Avatar
dpd
first,are you running headers? if you are still stock,the o2 in question is the one in the exhaust manifold.if you are running headers it is in the collector.the o2's for the cats are rears[after the cats]
Old Mar 20, 2006 | 06:11 PM
happa's Avatar
happa
Im running stock manifolds. It also had an "H" for history, so its happened before. Cant remember what it is, maybe its from the pervious owners. Thank you very much for the help.
To check engine light HELP!
