vararam air intake system
Old Mar 20, 2006 | 10:49 PM
advantage's Avatar
advantage
1st Gear
Default vararam air intake system
Does anyone have experience with the Vararam Air Intake system for C5's? I've had some tell me its great, others say no benfits. Is there something out there better? It sounds attractive to just bolt on some extra horsepower, but anything that easy usually doesn't produce the desired results. Any help is appreciated.
Advantage - '01 convertible, six speed with 15K miles.
Old Mar 20, 2006 | 11:04 PM
Silver98's Avatar
Silver98
Do a search, there is a ton of threads on this subject. FWIT, I installed the B2 on my 98 and love it. The install is pretty straight forward, and there is a seat of the pants feeling of more Hp. There is a noticable improvement >55 - 60 mph. That's the point where the dP across the front is sufficient to force more air into the manifold. Also, any thime you can cause the intake air to be cooler, (from the outside vs. inside the engine compartment) you will generate more Hp.
Old Mar 20, 2006 | 11:19 PM
jmautox's Avatar
jmautox
It does add power, but so does the zip tie mod, which is free, and takes less time to install. Zip tie mod dynos at +15hp on z06s pretty reliably, vararam dynoes at +18hp supposedly.
zip tie mod basically involves taking the cover off the air filter box
then using two zip ties to hold the air filter on
Old Mar 21, 2006 | 02:42 PM
myblackC5's Avatar
myblackC5
Default calaway
get a calaway intake.........works better that vararam. don't forget you have to pay another 50 bucks just to get a decent filter for the vararam. moving the MAF up a ways makes a big difference. i could tell right away when i first started the car that the honker worked.
Old Mar 21, 2006 | 03:29 PM
HRDTOPC54FUN's Avatar
HRDTOPC54FUN
Welcome to the forum. From what I see, the Vararam still makes the most gains but there have been posts here regarding installation difficulties and overall quality, thay finally came out with a better filter element. The guys that race like the Vararam, the extra 2-3 rwhp over the others is worth it to them.
Fact is just about any of the true cold air intakes will make something like 17-20 rwhp over the stock airbox. The CAI is a good first mod, add long tube headers down the road and really see significant gains -
45-50 rwhp that you can feel.
If I was buying a CAI today I personally woyuld go with the Callaway Honker - a lot of engineering went into it and the quality is top notch.
Others I would consider:
Motorsport Technologies Inc Ram Air
Breathless Performance Vortex Rammer
Lingenfelter Hurricane (they will be releasing a new CAI similar to the Honker soon)
Just my .02. Hope this helps.
Old Mar 21, 2006 | 03:48 PM
dputman's Avatar
dputman
5th Gear
Default vararam
I added the vararam to my 2003 zo6 and it was a noticable!!! kick in the pants torque difference. The car was wanting to go and I could feel the difference. It takes about 30 minutes of driving for the onboard computer to adapt. I have been very pleased with mine. I thought it was a good hp upgrade for very little money. Note: Keep the washable air cleaner clean. Once it starts getting dirty you feel the loss of power.
Old Mar 21, 2006 | 04:08 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
If your looking for the best bang with iffy (is that a word?) quality get the Vararam. I use the Vararam and I switched from the Breathless Vortex and increased my trap speed by over 2mph on the 1/4 mile. If your drag racing this IMHO is the best bang for the buck. Good Luck with your decision.
Bob
Old Mar 23, 2006 | 09:42 PM
kinyu's Avatar
kinyu
I asked this is another thread and did not get a response, so I guess I'll try in here. (Maybe the question is just too stupid and everyone knows the answer but me )
I noticed most other air intakes come with a replacement air bridge; however the VR does not, judging from the pictures. What is the reason for this? Would you get more HP if you put a different air bridge in?
Old Mar 24, 2006 | 01:07 PM
Gordy M's Avatar
Gordy M
The air bridge is just additional expense. It does not make more hp. GM has an adaptive strategy in the PCM to look for certain turbulence the bridge makes at the MAF, the bridge was designed to keep the engine quieter. While people talk about seat of pants, dyno, etc, It make no difference on an engine dyno.
When changes are made to the engine, you have several parameters in the PCM that must be updated before the long term effect of a change can be realized. Some items are only updated every ten minutes...it takes a good 40 miles minimum to see the net results.
Old Mar 25, 2006 | 12:43 AM
c5-pewter's Avatar
c5-pewter
c5-pewter
St. Jude Donor '08
In reference to the vararam discussion, I have an additional question. With the air intakes mounted into the open cowles at the very bottom of the car, what happens if one if forced to run through a flooded road, where the water is axle deep. Would this arrangement not choke and kill the engine? Thanks for any reply!
Old Mar 25, 2006 | 08:28 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
then you're screwed!
Old Mar 25, 2006 | 10:50 AM
rws.1's Avatar
rws.1
As with other after market intakes ...... hydralock ......
A poll of actual hydralock situations on the Forum showed other intakes had more reports of this problem than the Vararam B2
BUT it is a real possibility if driving through axel deep water
To vararam air intake system
