ls2 90mm throttle body
Old Mar 21, 2006 | 09:59 PM
dmitry_1998's Avatar
dmitry_1998
Default ls2 90mm throttle body
will the 90mm throttle body from the new ls2/c6 corvettes fit my 98 vette? Are there any necessary modifications or is it a direct replacement?
Old Mar 21, 2006 | 10:16 PM
Cory@LS2PortWorks's Avatar
Cory@LS2PortWorks
St. Jude Donor '09
LS2 has 4 bolts in a rectangular pattern. The LS1/LS6 has a three bolt mounting configuration. Won't work as is.
Old Mar 22, 2006 | 12:23 AM
ArKay99's Avatar
ArKay99
Also, the throttle body is 90mm, the LS1/LS6 manifold only has a 75mm opening. The electrical connector is different, and there is no coolant connectors. They will fit to a FAST 90mm and you can buy an adapter harness to connect it.
Old Mar 22, 2006 | 01:07 AM
dmitry_1998
i don't think the minimal gains are worth the trouble of trying to get this thing to fit.
Old Mar 22, 2006 | 08:49 AM
nikolai's Avatar
nikolai
unless you are planning or have a h/c setup, then you should at least look at an ls6 intake w/ a ported stock throttle body
To ls2 90mm throttle body
