Options for Rear Diff's
Old Mar 22, 2006 | 02:33 PM
98C5RT's Avatar
98C5RT
From: Somewhere between the Red and the Rio Republic of Texas
Default Options for Rear Diff's
I currently have a 3:15 ratio with an auto trans but want to bump it up some. I don't want to go to a 4:10 ratio but somewhere in between 3:42 and 4:10. I would like a ratio that will accelerate off the line but will not severely limit my top end. What are my options? What will the change do to my MPG?
Any suggestions? Thanks!
Old Mar 22, 2006 | 03:18 PM
94legaleagle's Avatar
94legaleagle
Two most common gears in your "asking range" are 3.73's or 3.90's -
I'm not sure what effect you will see on gas mileage, but I think from what I've read that 3.73's would give you the acceleration you want without reducing your top end too much.
3.90's are going to cut into (bring down) your top end speed more than 3.73's will.
Old Mar 22, 2006 | 04:03 PM
2000whitec5's Avatar
2000whitec5
From: 10.54 @ 129 346 N/A A4 Record 9.78 @ 139+ on 150 shot
if your car is a daily driver go with 3.42's and like a 2800 stall converter.. .. if you do the gears get the converter done !!! if you dont take a lot of long trips 3.73s and a 3200-3600 stall .. .. i have 3.73's and 3600 stall.. i hit 130 in "3" before i have to shift into overdrive so dont worry about top end... as for MPG .. you own a vette do you really care? .. but if you must know under normal driving i still get atleast 22 and i have other mods done.. hope it helps ..
Old Mar 22, 2006 | 04:14 PM
98C5RT's Avatar
98C5RT
Thanks for the responses. Sounds like 3.73 setup may be my best bet. As for the MPG, in the back of mind I know it doesn't really matter but I'd rather spend the $$$ on mods rather than gas. No long trips, mostly just to and from work.
I like to think of every red light as a new starting line
Old Mar 22, 2006 | 04:21 PM
next victim's Avatar
next victim
what ever you do, do not go with 3.90 those are a waste of money, a lot of people i have read and talked to that got those wruined their dif and wished they had never gotten it, those 3.90's are weak for some reason go with the 3.73 no problems there
Old Mar 22, 2006 | 04:41 PM
Face's Avatar
Face
Unless you plan on driving 160+ mph, gears will not ruin your top end. 3.73's off the best of both worlds, I'd recommend them.
Old Mar 22, 2006 | 05:45 PM
Mike Mercury's Avatar
Mike Mercury
Originally Posted by next victim
...(3.90 )a lot of people i have read and talked to that got those wruined their dif and wished they had never gotten it, those 3.90's are weak for some reason go with the 3.73 no problems there
source or links ?
Old Mar 22, 2006 | 07:17 PM
tiojames's Avatar
tiojames
Default gears
I went to 3:42s and 3500 yank from 3:15s. Gas milage went from 29-31 to 24-26. Thats a pretty good drop. I would not recommend going lower than 3:42s if you do a fair amount of highway driving.
To Options for Rear Diff's
