LS7 clutch
Old Mar 23, 2006 | 04:36 PM
badbreg's Avatar
badbreg
Default LS7 clutch
Is this clutch also made by Luk? and anyone know the weight of the whole setup? (clutch, flywheel, pressure plate)
Thanks in advance. Bob
Old Mar 23, 2006 | 04:40 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Not sure but it does seem to suffer from the pedal to the floor syndrome just like the other LUK clutches do.
Old Mar 23, 2006 | 05:29 PM
SnowyATX's Avatar
SnowyATX
Yep, I believe I recall seeing LUK stamped on mine before I put it in.
Old Mar 23, 2006 | 05:40 PM
ST0CKER's Avatar
ST0CKER
where did you hear that?
Dave
Old Mar 23, 2006 | 06:23 PM
unstressed's Avatar
unstressed
I created a thread on this a while back, but it is gone now.
If I remember correctly, PP, Disc, and Flywheel were a total of 50 lbs.
unstressed's Avatar
unstressed
Dave
http://forums.corvetteforum.com/show...186&forum_id=1
A guy in there says his LS7 clutch has the sticking problem.
Old Mar 23, 2006 | 07:29 PM
ST0CKER's Avatar
ST0CKER
man i sure hope thats not the case. I went w/ the ls7 clutch to fix the sticking pedal
dave
Old Mar 23, 2006 | 08:01 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default LS7 Clutch?
Does it have any special adjustments like the LS6 Clutch?
Bob K.
To LS7 clutch
