Radiator Replacement Question
Old Mar 24, 2006 | 05:37 AM
C3 Vette's Avatar
C3 Vette
Default Radiator Replacement Question
I need to replace my radiator, the drain fitting housing is cracked (plastic tank) and I do not want it to start leaking if I try to drain it. I am replacing it with a DeWitts so this will not be an issue in the future.
I recently replaced the skid plate (thanks for all the suggestions and responses I got on this from you all!), and did not notice the drain fitting condition at that time. My question is - can I remove the radiator from the top, and if so, do I need to remove the hood? The assembly manual (2000) says to lower the radiator (?). Does this mean that I have to reverse the skid plate install procedure (front bumper, skid plate, etc.) Thanks in advance for any and all suggestions!
Jack
Old Mar 24, 2006 | 07:14 AM
vettenuts's Avatar
vettenuts
No, it will come right out the top. The fans are removed by sliding in to the driver's side and then rotating the fan assembly counter clockwise so the passenger side disengages from the tabs. I took photo's so I could tell where all the wires go back. It is rather heavy, so a second pair of hands will help prevent scratches and banging up the fins in the condenser. Good luck.
Old Mar 24, 2006 | 04:36 PM
C3 Vette's Avatar
C3 Vette
Thanks for the information! I will let you know how it goes.
Jack
Old Mar 31, 2006 | 05:49 AM
C3 Vette's Avatar
C3 Vette
Thanks again for the help. The radiator went in in about an hour. There were no issues, and everything came out from the top. The most difficult part was the wire loom retainers, I ended up breaking a few and had to replace them. While I had it apart I cleaned the AC coil. It runs well, no leaks, and the gauge is steady at 200 degrees.
Jack
Old Mar 31, 2006 | 06:34 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Cool!!
Bob
Old Mar 31, 2006 | 11:14 PM
Dirty Howie's Avatar
Dirty Howie
Jack
You will love the Dewitts.....works great. Its amazing how small the stock one is!!
DH
To Radiator Replacement Question
