MAF Signal Output Wire
Old Mar 26, 2006 | 09:41 AM
SCannon's Avatar
SCannon
Default MAF Signal Output Wire
I am installing a Snow performance Meth injection kit. Can someone tell me which wire is the output signal on the maf?
Old Mar 26, 2006 | 09:49 AM
Patches's Avatar
Patches
Old Mar 26, 2006 | 09:52 AM
SCannon's Avatar
SCannon
So I take it I plug into the yellow wire? I was searching on sites and they all referred to the yellow wire as input. I guess they were talking about input to PCM.
Thanks for the help.
Old Mar 26, 2006 | 09:56 AM
Patches's Avatar
Patches
It is the output - from the MAF to the PCM.
Old Mar 26, 2006 | 08:32 PM
SCannon's Avatar
SCannon
I installed the system and have a problem. I checked the voltage signal on the yellow wire and it seems odd. When the engine is off but key on it shows 5 volts. When I start the engine and let it idle it goes down to 4 volts. When I rev the engine the voltage drops down to 3.5? Should the voltage start lower and go up as more air passes? In the instructions for the Snow Performance kit there is an example. It shows setting the module to turn on at 2 volts @ 20% flow and then at 4 volts flow 100%? Do I have a problem here?
To MAF Signal Output Wire
