Doing the H/C thing and....
Old Mar 26, 2006 | 02:33 PM
molson's Avatar
molson
Default Doing the H/C thing and....
I can't lift the steering rack up high enough to clear the tabs on the cross member
The rubber boot on the rack hits the bottom of the frame.
Any body got any tips/hints???
Keep in mind I am by myself so my options are pretty limited....I don't want to get the wife involved.Things could get ugly.
Mark
Old Mar 26, 2006 | 04:53 PM
Patches's Avatar
Patches
You'll need to slide it sideways some. It's a combination of wiggling it and rotating and lifting and sliding it. I've slid it both ways and it takes a bit of doing. I take it you're just sliding it towards the passenger side so you don't have to pull it all the way out on the driver's side. That's the best way - especially when you're doing it alone.
Old Mar 26, 2006 | 09:13 PM
molson's Avatar
molson
Thanks Patches....That is just what I had to do.
I sprayed some WD-40 on the side with the rubber bushing and it seemed to help.
An interesting side note...I went to loosen my crank bolt and found that it was already loose!!!
It took NO effort to remove it.
Looks like I avoided a BIG mess!
Old Mar 26, 2006 | 10:17 PM
BoostedBlkZ06's Avatar
BoostedBlkZ06
wow yea you did good thing
To Doing the H/C thing and....
