What is this????
Old Mar 26, 2006 | 06:04 PM
Gene Wolf's Avatar
Gene Wolf
Default What is this????
I found this lying loose on the inside of the front cowling, near the front right turn signal/ air vent area. Does anyone know what this is for and where exactly should it be mounted? This picture was taken through the gap between the hood and the front cowling with the hood open, but when I found it, it was lying below where I am holding it, on the lower inner surface of the cowling.
Old Mar 26, 2006 | 06:14 PM
bcseitz's Avatar
bcseitz
Is it the connection for your hood light???
Old Mar 26, 2006 | 06:18 PM
Gene Wolf's Avatar
Gene Wolf
No, I don't think so. The hood light works and so do all the other lights. I'm guessing it's some kind of a temperature sensor (?) because it doesn't have any place for it to connect to anything else electrically, but rather just has that short, cylindrically shaped probe.....
Old Mar 26, 2006 | 06:43 PM
ErnieN85's Avatar
ErnieN85
It's the outside air temp sensor there is a clip and it sticks through the radiator shroud righ about there on the on your left it measures outsid air temps infront of the radiator
Old Mar 26, 2006 | 06:47 PM
TPR492's Avatar
TPR492
St. Jude Donor '06
Old Mar 26, 2006 | 06:58 PM
Patches's Avatar
Patches
Old Mar 26, 2006 | 07:26 PM
Mike Mercury's Avatar
Mike Mercury
Originally Posted by Patches
Ed to the rescue (as usual).
Old Mar 26, 2006 | 08:19 PM
Gene Wolf's Avatar
Gene Wolf
Wow! You guys are awesome!! I found it just as your diagram described. Is this the best forum ever, or what? Thanks a million!
Old Mar 27, 2006 | 12:54 AM
vetred's Avatar
vetred
There it is!
To What is this????
