Clutch problem #123456
Old Mar 27, 2006 | 12:50 PM
astrolite's Avatar
astrolite
Default Clutch problem #123456
Hello,
First post here. Got a 97 C5 not too long ago. Been loving until just recently!
As of late my clutch pedal often sticks down to the floor about 3/4 and does not release until I pull it up. When this happens it seems to be very consistent (can be from a cold start or randomly while driving).
I was thinking it could be the spring that helps to depress the pedal, but when this problem occurs even with the clutch fully depressed I can not get in gear. I would think if it were the spring I could still push the clutch in and switch gears.
Thoughts?
Old Mar 27, 2006 | 01:21 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Do a search..this topic has been beat to death.
