engine cuts out
Old Mar 27, 2006 | 05:31 PM
DAKING's Avatar
DAKING
Default engine cuts out
02 z06 under hard acceleration engine cuts out at about 5000rpm then is ok, anyone ?
Old Mar 27, 2006 | 05:57 PM
dpd's Avatar
dpd
any faults?
Old Mar 27, 2006 | 06:01 PM
DAKING's Avatar
DAKING
Default cut out
no , no codes
Old Mar 27, 2006 | 06:06 PM
dpd's Avatar
dpd
explain cuts out.do you mean the motor skips/goes flat then comes back or do you mean it's like it's been shut off?
Old Mar 27, 2006 | 06:13 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
How many miles on the car? OEM Plug Wires?
Old Mar 27, 2006 | 06:36 PM
DAKING's Avatar
DAKING
Default cuts out
car has 22000 mi, it's done it for a while just seems like it shuts off for that split sec. checking the codes now, these are all history u1064 loss comm. with bcm another was for hor. pos sen fit whatever that is. another for column lock
Old Mar 27, 2006 | 06:45 PM
FactoryRaceCar
B2262 B2264 B2265 etc are for your door mirrors vertical and horizontal position etc. They dont have anything to do with your problem. How does this "cutout" feel like? Is it like "hesitation"? Or is it like you know when you hit the red line and the rev limiter "kicks" in?
Old Mar 27, 2006 | 06:47 PM
dpd's Avatar
dpd
possibilities: bad spark plug[s]{flashover}
plug wire[s]
do you wash the engine? if so,a corroded knock sensor???
partially plugged fuel filter[your car runs the old fuel system]
Old Mar 27, 2006 | 06:56 PM
BlueRag's Avatar
BlueRag
A buddy of mine with a 04 Z06 has been dealing with the same problem for about 2 months (misfire/stumbles at around 5400+ but continues to rev). His fuel pressure, injectors, pcm, coil packs, wires, plugs, tune, have all been tested/ replaced. No error codes to speak of. We're going to replace the CKP sensor because his tach signal seems to whack out during the misfires...........Let us know if you get your's figured out
Good luck
Old Mar 27, 2006 | 07:36 PM
Frankie2blue's Avatar
Frankie2blue
I Have the same problem on mine (02) with 7500 miles and never found it. I am wondering if the rev limiter may be set too low. Happens around 4900-5000 under hard accelaeration. Love to find the problem.
Old Mar 27, 2006 | 07:47 PM
DAKING's Avatar
DAKING
A lot of responses to this post , seems like a lot of guys have had this problem, someone will hit it on the head yet
Old Mar 27, 2006 | 08:13 PM
stano's Avatar
stano
Good luck
Hey Yelnats, maybe it'll be time for that 402 if the CKP isn't the fix...maybe a "group buy" on a couple huh!?
I hope the CKP is it though... I'm tired of dealing with all of this s***
I know, I know, that's modding though.
To engine cuts out
