Halltech Stinger = Decreased MPG??
Clayton from Las Vegas
Haltech Stinger
Kooks LT's High flow cats\X-pipe
LS6 intake
Z06 catback
*stock tune!!!
this is with the 3:15 gear ratio...
MAybe you used a heavy foot to test!
Actually, we recorded 32 mpg in 6th gear driving from Milwaukee to Chicago Heights, IL and back with the Stinger.
Here is how the Power Control Module works. During the first 15 or so miles the 20 Long Term Fuel Trims (one for each throttle position) relearn stoichiometric (a perfectly chemically correct burn or 14.68:1).
That is 14.68 parts air for every 1 part fuel, assuming gasoline or E-0.
If you get stuck using E10 (10% ethanol fuel) your mileage will go down a couple miles per gallon due to the fact that 14.68:1 is stoichiometric for 100% gasoline only. E10 requires a stoich ratio of 14:1.
Ethanol has about 60% the BTUs of gasoline, so 10% of your fuel is only producing 60% of the power the car needs to maintain level power in 6th gear.
We reprogram cars that are stuck with E10 here in WI by changing stoich to 14:1 for closed loop. The fuel mileage is still slightly less than with pure gasoline, but at least the power returns.
The other anolomly is the Cat Overtemp Protection circuit in the PCM program. It automatically adds fuel to WOT if it registers too much O2. We have seen mixtures as fat as 10.5:1 on the dyno because of this circuit kicking in.
This is another area we provide programming countermeasures to turn this circuit down a bit. It is very aggressive on the dyno, but not quite as bad on the street due to better cooling.
Jim
Thanks Jim for the interesting info in your post. The BP where I get gas doesn't have any ethanol.
Great product...well engineered and good customer service.
