Torque Tube Woes
Old Apr 22, 2006 | 02:35 PM
  #41
Mikelly's Avatar
Mikelly
YOu guys who are running the aluminum bushing, i'd strongly recommend getting the shaft checked when the aluminum coupler is attached. I'm in the middle of installing a carbon drive shaft and the runout on the aluminum coupler is amazing... You can SEE IT when the coupler is mounted. I took it off and installed a new, stock coupler front and rear...
Now if I'd just seen this thread sooner... I've got two rear bearings and NO fronts... And mine had play you can feel...
Mike
Old Apr 22, 2006 | 03:01 PM
  #42
Mikelly's Avatar
Mikelly
Doubelpost... sorry!
Mike
Old Apr 23, 2006 | 07:32 AM
  #43
Mikelly's Avatar
Mikelly
Originally Posted by servohead
How difficult was it to replace those bearings? Moreover, how difficult was it to remove the old ones?! Also, I thought I'd heard of people replacing the rubber joints on the driveshaft ends before, wouldn't that prove that the torque tube IS serviceable?
To answer your question, yes and no. The torque tube is very complex according to GM, so they chose not to release the parts to the public, just like their upper and lower balljoints.
I got a pair of couplers brand new from another member here who got them from Germany. I also got a replacement Carbon Shaft for the torque tube, and I have the rear bearings. However, the front bearing on mine was the issue as it had play, so now I'm in search of one. Typically when the front rubber coupler lets go, it takes the pilot bearing as well, which mine did, so now I have to replace that too!
I'd much prefer the corvette to have something besides this torque tube. In my opinion, they made a car capable of reving past the capabilities of the driveline, which the motor easily will do with mild mods and a tune. The T1 crowd rev past 6900RPMs all day long, and they have to budget in for a torque tube or two throughout the season due to this very issue. So when doing a tune on your Vette, if the tuner wants to raise your RPMs, just keep in mind that unless you upgrade to a carbon shaft, you're doing some serious damage to the torque tube... And see my post above concerning the aluminum coupler...
Mike
Old Apr 23, 2006 | 09:35 AM
  #44
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
ATI(on the left<<<, not the blower people, not the pulley people the 3rd ATI) will ck the front of the shaft for runout, most members on the f/i board run urethane up front and solid in the rear
Old Apr 23, 2006 | 09:37 AM
  #45
SteveDoten's Avatar
SteveDoten
is the actual torque tube different from the 97-00 vs. 01-04 cars? GM added the upgraded TT across the board in 01 w/ the start of the Z06
is it just the bearings that changed? same ID and OD?
Old Apr 23, 2006 | 09:43 AM
  #46
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Good read and allot of good info. I'm filing this one away...
Bob
Old Apr 23, 2006 | 10:41 AM
  #47
Mikelly's Avatar
Mikelly
The whole tube diameter and assembly is larger, except for the input and output shafts is what I was told. It's a direct bolt in though.
As for the comment about the aluminum in the rear and rubber in the front, I know, I know. I did that same exact setup on mine, mounted in the rear, had runout. What that means is, the whole assembly was not spinning properly with zero offcenter. Mine was bought from a very popular vender, and I bet mine is just like yours and was probably made in the same place. If that is the case, then they are ALL out of center, Which in turn prematurely tears up the front rubber coupler.
For the record, I've never tried to run my car up to 6500-6700 rpms like some of the guys who I DE with. I just didn't want to hurt the motor, so I'd always shift it at 6000 rpms or below. I fully believe this aluminum coupler is part of a bigger problem, causing more harm than good, unless the driveline is properly balanced.
Just my $.02!
Mike
Old Aug 22, 2010 | 05:23 PM
  #48
00Corvette's Avatar
00Corvette
Originally Posted by 5.0_CJ
Alright gentlemen...
http://jadefalcon.shackspace.com/Pics/howto_tt/
(preliminary picture dump of what I did tonight)
It's fun and not so fun being the first guy to how-to a torque tube rebuild, so I'll let you know what I learned tonight.
It's pretty simple. The snap rings are a bastard, like they always are, no matter how good a set of snap ring pliers you have. The bearings are actually pressed into the aluminum housing easily, I used a torch to heat the carrier up and they pressed out like soft butter. Heres the bad part:
There is another bearing in the carrier not mentioned in previous posts, and theres a part thats going to be a bitch to replace... here is the part list you will need to rebuild a corvette transaxle (minus any couplers):
(1) 6007 2RSJEM 35mm (schem ref #24)
(1) 6008 2RSJEM 40mm (schem ref #37)
(1) 6010 2RSJEM 50mm (schem ref #31)
(1) 35mm Slinger Collar (schem ref #22)
-click-
It's important to note that the part numbers above are SKF part numbers, I myself used Nachi bearings for less than half the cost of SKF bearings. I will supply the Nachi part numbers when I do the final on the torque tube rebuild.
Now, all of these I can get my hands on, except for the slinger collar.. thats a GM part they dont sell, as far as GM is concerned, the entire driveshaft inside the torque tube a single part... so now I have to find where in the hell to get one.
Hello,
Are you 100 percent sure on that 6010 bearing? Just about every write up that I can find on these things says (2) of the 6008 bearings and (1) 6007.
My car is a 2000 Automatic.
I already bought (1) 6007 and (2) 6008 bearings. Now I have it all torn apart, can't get the snap ring out and don't know what the heck to do about these bearings?
Also, when did you remove your front plug bolts that were put in place of the plastic plugs? How did you re install them to make sure that the new bearing was aligned/balanced properly?
thank you,
Donnie
Old Oct 10, 2010 | 09:29 PM
  #49
speedyhawk101's Avatar
speedyhawk101
Originally Posted by 00Corvette
Hello,
thank you,
Donnie
seems like you need the 6007, 6008, and 6010 as stated in the thread for the 97-00
01-04 got the 6007 and (2) 6008's
I haven't disassembled/assembled one of these but my guess is that the bearing is a straight forward install. It self centers by being installed on the shaft and the outer race of the bearing likely seats in the housing on a ledge or a flange if you will.
It should be a simple task overall. Temperature Differential method is preferred for bearings that have an interference fit.
If the OD of the shaft is lager that the ID of the bearing, heat the bearing and cool the shaft. If the ID of the housing is smaller that the OD of the bearing, Heat the housing and cool the bearing. Use a heat gun if you have it and large freezer works wonders. Also use some lube on the mating surfaces.
Old Oct 10, 2010 | 10:26 PM
  #50
00Corvette's Avatar
00Corvette
I used just the 08/07 on my 00, now issues after 500 miles so far..
Old Oct 11, 2010 | 11:21 PM
  #51
RX-Ben's Avatar
RX-Ben
P/N for the bearing slinger is 12456208
for the O rings (2 needed) = 12456220
See HERE
Old Oct 23, 2010 | 02:03 AM
  #52
Mike Yeager@Eastcoast Performance's Avatar
0Mike Yeager@Eastcoast Performance
Former Vendor
Default Hey guys, check our specials out.!!!
We have rebuilt and sold thousands of parts for Corvette Torque Tubes over the past 14 years...Take it from someone who knows corvettes & corvette performance parts...If its a street car at least install our truely German Rubber couplers in the front & rear of the propeller shaft...If you want to make your set-up as strong as possible without busting your walet then use one of our CNC'd Billet Aluminum BALANCED Couplers in the rear...LMK if I can help any of you guys...We have it all instock!!!
Hey guys, we just received our shipment of Brand New LS7 Clutch Kits, they are instock ready to ship the same day you order...We also have all the accessories to complete your clutch install...
LS7 Clutch Kit ....$429
Includeds Flywheel, Disc, Pressure Plate & Alignment Tool...
C5 Remote Clutch (One Man) Speed-Bleeder Kit $59.99 w/Clutch Purchase
C6 Remote Clutch (One Man) Speed-Bleeder Kit $69.99 w/Clutch Purchase
ARP Flywheel & Pressure Plate Bolts Both $49.99 w/Clutch Purchase
TORQUE TUBE ACCESSORIES...
Torque Tube Bearing Kit (3 Bearings) $199.99
10mm & 12mm CNC'd Billet Aluminum Torque Tube Couplers, The units we make are Truely BALANCED...!!!
ECPC Billet Aluminum Balanced 10mm Couplers $139.99 each
ECPC Billet Aluminum Balanced 12mm Couplers $145.99 each
(the good ones, these say Made In GERMANY)German 10mm Rubber Couplers $99.99
(the good ones, these say Made In GERMANY)German 12mm Rubber Couplers $99.99
C5 Accessories....
C5 Z06 Clutch Master Unit $89.99
C5 Z06 Clutch Slave Unit $99.99
C5 Z06 Throw-Out Bearing (the good one) $39.99
LS1 & LS6 HD Pilot Bearing $14.99
C6 Accessories...
GM C6 Z06 Clutch Master Unit $119.99
GM C6 Z06 Clutch Slave Unit w/throw-out Bearing $199.99
LS2,3,7 HD Pilot Bearings $19.99
CARBON FIBER DRIVE SHAFTS on Special $999.99
We accept Visa, MasterCard, Disc, Amex, Paypal and Cashier Checks!!!
Old Oct 23, 2010 | 02:28 PM
  #53
speedyhawk101
Mike
Do you get any increased Vibration with having the SOLID couplers? Is that why the recommendation for one rubber one billet?
Old Oct 25, 2010 | 12:13 AM
  #54
Former Vendor
Originally Posted by speedyhawk101
Mike
It really depends on what has been done to your car...call me and I will be glad to explain...
