C1295 Fault
Old Oct 25, 2010 | 06:39 AM
seoulbrooks's Avatar
seoulbrooks
Default C1295 Fault
I read the low LED tail light current draw can cause codes. In my case, the LED tail bulbs appear to be causing code C1295 (Brake Lamp Switch Circuit Open), which causes codes with the Active Handling and Traction Control (same circuit for some reason). I have the hyper flash unit installed and no problems there.
Anyone know a fix for this? Will load resistors fix this fault and if so what size should I use? Thanks for any help.....
