My car is sick
Old Aug 16, 2001 | 06:01 PM
fairway's Avatar
fairway
Default My car is sick
Today I drove my car to store and back about 8 miles around trip when I pull in driveway I see that my rpms have droped I turn down radio and step on gas and the car has no power and I hear a noise in back when I let cluch out anyone have this problem before? :(
Old Aug 16, 2001 | 06:07 PM
MelissaC5's Avatar
MelissaC5
Default Re: My car is sick (fairway)
I feel your pain. :cry
Hope it feels better soon.
Old Aug 16, 2001 | 06:19 PM
MDT's Avatar
MDT
fairway,
Could you provide a few more details. Was it running well on the trip to and from the store? When you say it has no power sitting in the drive, do you mean it won't rev in neutral? Tell us a little more about the noise.
If you haven't checked for codes, that could be helpful in trying to get a diagnosis.
Good luck.
Mark
Old Aug 16, 2001 | 06:29 PM
fairway's Avatar
fairway
The car will start fine I was going to drive around block and it seems like it is going to die out so I pull back in garage I jack up rear start car and put in first and it sounds like maybe cluch or trans make a noise but motor is NO POWER will have to take to shop my very first problem and it don't sound good.
Old Aug 16, 2001 | 11:29 PM
WOEII's Avatar
WOEII
From: [QUOTE=onedef92]Remember when that spookable closed the door on that mofo and trapped him inside tha
St. Jude Donor '06 thru '11
Mabey she just need a teaspoon of octane booster. :smash:
Old Aug 17, 2001 | 02:47 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
A double shot of Zaino might cure its ills!
Old Aug 17, 2001 | 05:26 PM
kraff's Avatar
kraff
Default Re: My car is sick (wallstAL)
And a double shot of Jack might cure yours.
Good luck! :D
Old Aug 21, 2001 | 12:03 AM
fairway's Avatar
fairway
Well got my car back todayit had a code P0300 random misfire.Shorted injecter circuit.They performed spark test and all ok performed injector balance test found four inop.ck fuses found blown injector fuse #2.Diagnose further until found short under ls vc cover under fuel rail.They repaired short and replaced fuse.Parts $6 dollars and labor $172 I wish someone could had save me the 172 in labor just keeping everyone up to data on on my bad foot vett :D
Old Aug 21, 2001 | 02:32 AM
MDT's Avatar
MDT
fairway,
Thanks for the update. Glad they got ya goin' again.
C5-TECH has advised in several posts, that the left side injector harness is subject to shorting to ground because of chafing at the metal loom. As I recall he said #7 and #5 were most often the ones to have a problem.
Good luck.
Mark
Old Aug 21, 2001 | 08:59 AM
fairway's Avatar
fairway
I must have missed that post. :confused:
Old Aug 21, 2001 | 01:08 PM
Arkay's Avatar
Arkay
My guess is you got some bad gas and the fuel filter may be hosed. Have it checked before letter them do something major. I assume they can test for fuel pressure.
Dick
2001 Black Coupe
To My car is sick
