Anyone Remove the Battery Surround ?
Old Mar 30, 2006 | 07:54 PM
Dave1998's Avatar
Dave1998
Default Anyone Remove the Battery Surround ?
I took mine out last fall to do some engine work and I am asking if their is any point to put it back in?
So what do you think ?
Old Mar 30, 2006 | 08:09 PM
ErnieN85's Avatar
ErnieN85
Put i back it helps keep the battery cool and heat helps to kill your battery (they go bad fast enough)
Old Mar 31, 2006 | 08:54 AM
Dave1998's Avatar
Dave1998
any other thoughts ?
Old Mar 31, 2006 | 10:59 AM
ErnieN85's Avatar
ErnieN85
Well it really doesn't weigh much. So why take it out?
Old Mar 31, 2006 | 12:56 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
I don't have one.
Old Mar 31, 2006 | 02:30 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
its there to catch battery acid when and if the battery has an issue.
Luckily it worked when my factory a/c delco decided to puke.
Old Mar 31, 2006 | 06:22 PM
LoneStarFRC's Avatar
LoneStarFRC
Plus it helps keep the dirt/sand/general crap away from the battery/fusebox area too. There's a lot of wiring harnesses over behind the battery, plus the PCM and TAC module is/are underneath the battery too. The extra protection is worth keeping it IMHO.
Old Mar 31, 2006 | 08:10 PM
Dave1998's Avatar
Dave1998
Ok, I am putting it back in to get it off my workbench !
Old Mar 31, 2006 | 08:24 PM
cenzo's Avatar
cenzo
I strongly suggest, if you haven't already done so, that you remove, clean and reassemble that ground stud (G104) under there before you replace the shroud.
Old Apr 1, 2006 | 06:30 AM
ErnieN85's Avatar
ErnieN85
Now I can apreciate that!
I have to clean up mine too
Old Apr 1, 2006 | 09:04 AM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
I threw mine away when I installed a Sear's Die-Hard battery about 30,000 miles. No problems have come up yet.
Tom
To Anyone Remove the Battery Surround ?
