I know, another Piston Slap Question
I have yet to talk to an engineer who can tell me piston slap is desireable, only that it's acceptable on a racing engine with forged pistons. And as I've stated before, if it's engineered in and not a tolerance issue, how come all my pistons don't slap, instead of only one?
I expect piston slap on my forged motors, but not on one with cast hypereutectic pistons!
But it appears there's no use arguing. We're supposed to just drink the KoolAid fed us by GM and dealer employees.
I am a mercedes tech and benz v8 do not have steel or iron liners in their aluminum blocks. The piston rings ride against a aluminum clynder wall. The walls are treated in a way that all the moloucles stand up on end and are actualy harder than steel would be. Its engeneering like this that foren cars are winning. I've seen these engines commonly with 200k and as much as 400k with almost no wear. The AMG motors with renntech kits have 600 or more hp with simply a blower pully change. The piston slap IS a problem reguardless. They should be able to make a strong motor that dosen't sound like crap and beat its self apart. Just imagine how long these engines would last without synthetic oil. My guess would be less than 100k. The build qiality of these cars just **** me off. If it wasen't going to mod it I would of baught something else, forien. I hate getting out of a foren car whare everthing fits well and doesnt squeak or rattle into my c5. When I step in I am welcomed by my creaking cheap plastic center counsil and my rattling door i have to slam (i replaced my rocking stock seats). Then I hope my coloum isn't locked up, and maby my headlight switch will work the first time.
I'm glad gm is almost bankrupt. Maby they will finnaly change. As for now I am looking for a forien daily driver. maby a C43 or a WRX or a TL or somthing
. I could pull repair orders for vehicles with over 100k and a "piston slap" noise that don't burn oil or lose any performance due to it. So when you find a reason to be concerned about it (besides that it is annoying) then let us know.
My '00 FRC is autocrossed, cruised, road trips, etc., right now 138K+ miles and counting. I run an external oil cooler, track temps don't exceed 250 degrees. I just got back from a 800+ road trip and got 28-30 mpg.
Oil is changed when oil life monitor gets to 0% (usually around 7-8K miles, depending on track days) and analyzed by Blackstone labs. No anomalies in the analysis have been found, and metal counts are nice and low.
Piston slap is evident on cold starts and goes away within the first mile. So, apparently piston slap has given me little or no grief.
Just FYI for those that are not perpetually spun up on this issue.
HTH, and have a good one,
Mike
I have made a new video of my car and it’s knocking, tapping, ticking engine. I’ll work on the edit and post it sometime tonight. Check back for a link, and take a listen for yourself. You can’t argue with the proof.
You know you are right I have heard noise but none of what you guys are talking about. We have over 400 corvettes in or club and various clus around us. I email this thread to all of then to see if anyone come back telling me of this issue, but you are right I can't disagree with proof. have placed the link on the forum yet? I will forward that too . but thanks for the heads up.
Bill
I also noted in your profile this:
Why a Corvette? well, I have never owned one before, and the C5 represents a high standard
I too thought the corvette was built to a high or higher standard. I even took a trip to Bowling Green and toured the manufaturing plant a few summers ago before I bought my car. I was in luv, and nothing was going to spoil that but a knocking, tapping, clicking ticking engine. That's not the high standard I was expecting.
1 live with it...
2 sell the car and buy something else...
3 fix it.
i understand that the idea of having to pay a fair chunk of change to fix something is uncomfortable, especially when you believe that it should be a warranty issue. But when you look at the overall picture, If it allows you to enjoy the car more, then why not? People replace ugly wheels, upgrade suspension and brake parts, add HID headlights, and on and on... all for the sake of getting more enjoyment out of the car. Why should an issue like this be any different? GM will fix your car if it goes T.U. during the warranty period, and beyond, if you bought an extended warranty. They have taken the position that the noise is not an indicater of a problem, and the mileage that these noisy engines live to seems to bear that out.
So, for me, if it was my car, and the noise bothered me, I would just fix it.
Life is too short to have to live with compromise, especially when you have the power to change it.
My "other" car is a 02 DeVille. My first Cadillac, and I LOVE that car. It spoiled me with a quality build and one of the best V8 engines ever made. If GM can build that engine to run quite, perform with more than ample power and pass anything on the road I wish, including gas stations, then why isn't the LSx engine able to idle without knocking?
Regards, Greg
Bill
All I'm saying is that american quality has been slacking for years and americans are catching on. If ford and GM want to stick around they are going to have to step up to the plate.
MY motor rattles
Just keep test driving until you find one that rattles then buy it, because that one will have more power. If you are interested in performance you should have a loud enough exhaust so you would never notice a little ticking anyway!!!
Mike
Good feedback!
For example, these cars don't really handle all that well, and they hate bumps. Like you said, interiors start rattling to death over time, and after so long, we get tired of all the clunks and rattles. At the same time, newer, and better designed cars come along, and we go buy those. So, I think GM thinks as long as the motors last "long enough", why bother?
With that said, yep, 100k miles used to be a milestone for American cars. So, now American manufacturers can say, "Look, our engines now last longer than 100k miles, If you want more out of it, you may possibly have to put some work into it. But, we are giving you more bang for your buck nowadays, aren't we?" And, we cannot deny it.
I went to a Benz dealership two nights ago. I looked at several different models that ran $100k! Holy sh|t! That was only for some decent-looking sedans, and OK-looking sports models. And, that wasn't even looking at kick-*** styling and performance. But, the point here is that it obviously costs a LOT of money to make those killer tolerance cars, like you mentioned. A Vette is 1/2 the price, and I guess you get what you pay for.
