Another Leaky Diff... (PICS) Tips appreciated!
Old Mar 31, 2006 | 01:34 AM
txhorns281's Avatar
txhorns281
Default Another Leaky Diff... (PICS) Tips appreciated!
Well, just bought an 02 Z, 21K on the clock and a leaky **** of a diff. What's interesting though is it's my passenger side leaking, I hear more stories about the driver side. Anyways, I got it up on a lift and was inspecting around and notice the leaky side axe has like a mm or 2 more seperation from the diff case than the driver side (see pics). Is this normal or is this the primary cause of the leak? I have a new axle seal and O-ring, just wanting to see if anyone else noticed had this seperation when they had leaks. Any tips/comments appreciated! Thanks
Leaky Passenger side:
Not Leaky Driver side:
Old Mar 31, 2006 | 11:54 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
I'm sure if you've read enough posts you are familiar with the standard fix for this..
As far as the position of the half-shaft, don't sweat it. It can "float" several mm between bottoming and hitting the retaining c-clip.
Old Mar 31, 2006 | 12:43 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
txhorns281 - welcome! Congrats on the Z06.
Old Mar 31, 2006 | 05:10 PM
txhorns281's Avatar
txhorns281
Hey there Bink, long time no see! (Of course that's my fault for doing more lurking than posting over on LS1tech these days)
Old Mar 31, 2006 | 10:42 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
fix it yet? pull this off
pop the cover and replace the seals
Old Apr 1, 2006 | 04:25 AM
txhorns281's Avatar
txhorns281
that's the plan
To Another Leaky Diff... (PICS) Tips appreciated!
