Bleach :-(
Old Mar 31, 2006 | 06:53 PM
MedChoice Tony's Avatar
MedChoice Tony
Default Bleach :-(
Some contractor was pressure cleaning my garage and when I lifted it...some of the water went on my black beauty..Now..there are about (10) marks that look like water marks but will not come off ...besides writting a letter to the company, is there anything I can use to help get the marks out of there or not?????
Thanks,
Upset
Old Mar 31, 2006 | 07:23 PM
noran01's Avatar
noran01
Thanks,
Upset
how many forums are you going to post this in?
Old Mar 31, 2006 | 07:44 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Thanks,
Upset
You lifted the door, knew it was wet from the pressure wash, so I don't see how it is the contractors fault and writting a letter will help. Take a pic of the spots and posted it in the car care section if you have not done so already. The detailing gurus can help you out.
Old Mar 31, 2006 | 07:55 PM
skip89's Avatar
skip89
So, why does it matter if he posts in different places? Does anyone else have any positive advice to the posters question?
Old Mar 31, 2006 | 08:02 PM
VETTING's Avatar
VETTING
Thanks,
Upset
Try using a clay bar. Follow the directions. Good luck.
Old Mar 31, 2006 | 09:05 PM
MedChoice Tony
Thanks for the info.....sorry about posting in more than one forum... more responses
Thanks,
Tony
Old Mar 31, 2006 | 09:09 PM
Hogfish's Avatar
Hogfish
Thanks,
Upset
With any luck they are like sun spots, the sun has heated it and in essence burnt it into the paint. I have had water do this to my car. Get out your buffer and some wax, I was able to get the spots out of my car, hopefully you can to. If that doesn't work you might have to try some rubbing compound.
Old Mar 31, 2006 | 09:25 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Thanks,
Tony
After looking at the threads you have posted, almost EVERY thread you have started you have done it in MULTIPLE sections of the forum.
Based on your post count you are fairly new here. So just so you know, you are only allowed to post one thread on any one topic. After that thread has gone a page with little to no responses, you are allowed to post it in a different section. If you dont follow those guidelines, the mods will start deleting your threads.
BTW, I would try some sort of light rubbing compound. After that, polish it out.
Old Mar 31, 2006 | 09:35 PM
MedChoice Tony
I will try that, and thanks for the advice...
Tony
Old Apr 1, 2006 | 12:41 AM
beden1's Avatar
beden1
The same exact thing happened to me last year. It's hard to get ALL of the water out of the garage door without opening it first! I also had some spray on the car that had worked it's way through the closed door. Fortunately, I just had to use Maguires' spray detailer and it took all of the water spots off without any damage. Be careful with compound on your black paint. If you have to use anything stronger, start with a paste wax, and if that doesn't work - a cleaner wax for clear coat paints - and finally if no success, use 3M Finessit liquid. Start with a watered down solution, and add more product to your solution until it works. Then polish with a paste wax. Finessit is a finishing product, and the last step to polish a fresh paint job. Excellent product.
Old Apr 1, 2006 | 04:26 PM
MedChoice Tony
Thanks for all the info...I got a rubbing compound from "turtle" and will try that...
Thanks again...we'll see..
Old Apr 2, 2006 | 06:46 PM
Ron71's Avatar
Ron71
A 50/50 mixture of vinegar and water works great for water spots.
Old Apr 3, 2006 | 12:49 PM
DAWS C5's Avatar
DAWS C5
Old Apr 3, 2006 | 06:57 PM
VET 350's Avatar
VET 350
Holy Cow.....I would have died!!!!!
To Bleach :-(
