Front Leaf Spring Problem! Help!
Old Apr 1, 2006 | 10:05 PM
PatriotVette's Avatar
PatriotVette
Default Front Leaf Spring Problem! Help!
I noticed a week ago that my front leaf spring seems to be damaged on both sides near the cradles. It doesnt look damaged all the way (depth wise). The best way i can describe the damage is that it is splintered near the cradles like a piece of wood would be splintered. I have not noticed any driving problems and i dont know how long it has been like this. I was wondering how long i can ride with it like this. There is a vette cruise going on tomorrow and i am very anxious to go. What would i need to do to fix or replace this leaf spring. If i replaced it with an upgrade would i need to do the rear as well or replace anything else?
Thank you!
Old Apr 1, 2006 | 10:14 PM
Dirty Howie's Avatar
Dirty Howie
Thank you!
Not sure where the cradle is....but my front is splintered at the leading edge at the end near the adjuster bolt hole. I monitor it from time to time and it doesn't seem to be getting worse. It also does not affect drivablility.
DH
Old Apr 1, 2006 | 10:24 PM
Ducati749's Avatar
Ducati749
well if the leaf spring is splintering there is definately something wrong...best bet is to replace asap..if it happend to snap the car may bottom out, that would be ugly at any speed...and if it were me id replace both since it sounds as if you have a faulty leafspring and chances are the rear may have been under the same conditions...probably fall under warranty, but a great excuse to go Z51 front and rear........not what i know just what i think.........
Old Apr 1, 2006 | 10:27 PM
PatriotVette
I am not sure if it is called the cradle but it is the area more towards the center of the car. It looks like two brackets. The splinters start where each bracket is and then splinters about three inches in the direction towards the tires. I hope this description helps.
Old Apr 1, 2006 | 11:00 PM
Rex99Coupe's Avatar
Rex99Coupe
My front spring was splintered too. I wasn't comfortable with a performance car that had a faulty spring. Replaced front and rear with Z06 springs, swaybars, polyurethane bushings and Bilstein Sport shocks. Figured I might as well do it all at once. Expensive but well worth it.
Old Apr 2, 2006 | 12:35 AM
Ducati749's Avatar
Ducati749
how do you like the polyurethane bushings, do they squeek at all...did you install them yourself..
Old Apr 2, 2006 | 01:01 AM
460HP-YLO-JAKT's Avatar
460HP-YLO-JAKT
Any pics available?????????????????????
Old Apr 2, 2006 | 01:49 AM
jrc27's Avatar
jrc27
Cruise-In IV Veteran
Cruise-In V Veteran
I think all leaf springs on the c5 splinter....i replaced mine last summer
Old Apr 2, 2006 | 11:09 AM
Rex99Coupe's Avatar
Rex99Coupe
No squeeks, I used the lube supplied with the bushings. I installed eveything myself, LS1howto.com instructions are excellent. Ecklers carries the poly bushings. For Z06 swaybars front: 30mm part no. 44872
rear: 23.6mm use 24.5mm part no.45707
Old Apr 2, 2006 | 12:49 PM
Ducati749's Avatar
Ducati749
thanks for your info, i just ordered the new bushings....sorry to the writer, for heading off topic
Old Apr 2, 2006 | 10:29 PM
PatriotVette
No apologies needed, I wanted to know the same thing, we all are learning here.
Where can someone get a suspension upgrade package at low cost, besides ecklers?
Old Apr 3, 2006 | 07:28 AM
Rex99Coupe's Avatar
Rex99Coupe
Bought Z06 springs and swaybars from GMpartsdirect (Forum vendor) I bought Bilsteins from Shox.com and Poly bushings from Ecklers.
Old Apr 3, 2006 | 11:08 PM
Ducati749's Avatar
Ducati749
Ive had good experiences with westcoast corvettes, as well as corvette garage........
To Front Leaf Spring Problem! Help!
