m6 problem please help
Old Apr 2, 2006 | 08:43 PM
fotoboy's Avatar
fotoboy
Default m6 problem please help
98 m6 430+ rwhp
Ram powerspec 900/300 New 2004 slave, adj master
Have had issues with notchyness of clutch ever since put in has gotten better the more I drive but still cant shift as fast as when I had the stock clutch
Problem now: out driving car after running her hard, drove home fine stopped to open garage door whnt to engage 1st gear and started to hear a grinding noise pulling in garage. No matter what gear I enguage m6 it makes a grinding noise that sounds like it is comming from the bell housing, car enguages fine in every gear and moves car when let clutch out, does not make noise when in N with pedal in or out and shift into every gear with pedal in, car acts normal othewise but just makes nasty noise when I let the pedal out. The sound of the grinding does change if I let the clutch out at different RPMs.
update: car will continue to creap until pulled out of gear, noise continues until let pedal out
Thoughts?
