98 Vettes and cold air systems
Old Aug 17, 2001 | 12:46 PM
skip89's Avatar
skip89
Default 98 Vettes and cold air systems
My 98 is stock and runs well with no issues. I am thinking of adding a Vortex or K&N intake at Carlisle next week. I have been reading that the 98 cars run rich and the intake will put in more air. This will lean out my 98, make it run better. Is this right or wrong? Thanks, Skip
Old Aug 17, 2001 | 01:16 PM
Speed-Racer's Avatar
Speed-Racer
Default Re: 98 Vettes and cold air systems (skip89)
No, it will not cause any issues. They only run rich because of the FP and settings in the early years for safety. They leaned them out 99+
Speed-Racer
Old Aug 17, 2001 | 01:24 PM
skip89's Avatar
skip89
Speed racer, did the vortex make a real SOTP difference in your car? Also at full throttle does it sound louder/better? Thanks Skip
Old Aug 17, 2001 | 01:37 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Aftermarket Air filters allow more airflow, but the air is still metered quite effectivly with a non modified MAF. You should be fine.
Old Aug 17, 2001 | 05:35 PM
Mystery Fan's Avatar
Mystery Fan
Skip,
I have a '98 and added a MTI Ram Air. I could tell an immediate difference. Lowered my ET in the 1/4 by .35sec. It is louder than before, but at WOT. It sounds stronger.
Old Aug 17, 2001 | 05:58 PM
98vettecpe's Avatar
98vettecpe
My 98 has had a K&N twin filter system since new. It works great!
Old Aug 17, 2001 | 07:37 PM
Cosmo Kramer's Avatar
Cosmo Kramer
skip89.......Been running a Vortex for over a year. No problemo. If your C5 is stock and you plan on doing mods, do them in this order:
1) Vortex
2) Exhaust (x-pipe, optional)
3) TTS POWERLOADER!!!!!
4) Pull up the tirerack.com and order a new set of rear Goodyears - your gonna need 'um!!
To 98 Vettes and cold air systems
