Window Commander for the C5...details inside
The Window Commander gives you the capability to raise and lower the power windows with the factory key fob remote control. The driver side window has a one-touch auto-up control like the factory auto-down function. Detailed operating instructions and special notes are listed on the last page of the instructions. This product is designed so a person of average mechanical skill can perform the installation with these detailed instructions. However, if you are uncomfortable with this type of automotive interior work, any professional alarm/stereo shop should be able to do the work for you. Installation involves placing a small enclosure in each door, requiring removal of both door panels. There are four (4) connectors to plug inside each door as well. No wire cutting is required. Expect approximately 1 hour for installation.
Click here to order:
http://www.stores.yahoo.com/corvette...comspecen.html
RG
It only took about 20 minutes to install the first one, and only a few minutes for the second.
I have to crawl out the hatch in my coupe because I can't open the doors on the trailer without hitting the fenders. Once I have the harness bar in, I won't even be able to do that!
Guess I should order one sooner rather than later!
Mike
