Temp Sending Unit
Old Apr 5, 2006 | 02:19 AM
AZBrewer's Avatar
AZBrewer
Default Temp Sending Unit
Problem: Temperature rizing to 240+ quickly, few minutes.
Its not the antifreeze, not the thermostat, not the fans, not the hozes, the engine is not even hot to the touch. I used a temp gun (point and measure) at many points in the engine and radiator hoses and they are all low, around 100 +. Even the exhaust was only a little over 100.
I'm thinking its got to be the temperature sending unit. Can anyone give any advice on finding this and fixing this. Or if it can be anything else.
Old Apr 5, 2006 | 03:43 PM
Ducati749's Avatar
Ducati749
Default air might be traped in your engine..
check your heater does it still work properly? if it does not blow out hot air then your ac lines may have clogged causing air to build up inside the engine....this happened to me once, I cleaned out my ac lines with a pipe cleaner, and ran the engine hard to push out the air...what happened was the air was trapped where the temp sensor was in the cooling system, given that air heats up much faster than the coolant, the engine gets a false indication of real temp....hope this helps...
Old Apr 5, 2006 | 06:24 PM
vettenuts's Avatar
vettenuts
Sensor is right in front of the #1 spark plug.
Old Apr 7, 2006 | 01:18 AM
AZBrewer's Avatar
AZBrewer
I changed the temp sending unit. Its now runs a little different, but still has problems. The temp will rise like before, but will fluctuate. For example, it will go to 240, after a couple of minutes it will start to drop to 220, then up to 230, then 215, then 240, ... The temp will change every 3-5 minutes.
The heater works fine.
Whats left? Could this be the gauge itself, air in system? Any tips on removing the air out of the system.
Old Apr 7, 2006 | 07:30 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Have seen several temp sensor failure reports here over the years... not common but would appear to be your problem.. inexpensive sensor, contact gene culley at fred beans a forum vendor. Also have your vin # handy.
gculley@fredbeans.com
Old Apr 7, 2006 | 09:02 PM
vettenuts's Avatar
vettenuts
I have never tried this, but take the line from the head cross-over off of the throttle body. Hook up a Miti-vac and pull a little vacuum on the block to see if any air comes out. If you keep the hose high, you might be able to get any air if there is some. Honestly though, I have my heads off right now and have inspected the block with a boroscope and I don't think you could trap air in the block.
To Temp Sending Unit
