high flow heads
Old Apr 6, 2006 | 02:21 AM
1996man's Avatar
1996man
Default high flow heads
whats the best flowing head for the LS1/2/6? i know you can get C5R heads to flow over 400cfm but im not sure how you would get ahold of those and i htink they need a custom intake anyway. What are you guys with really high rwhp numbers running in the way of heads? how much CFM do your heads flow and how much power are you putting out. Im curious who makes the best flowing head for a car using either an LS6 intake manifold or a FAST LSX intake manifold.
Old Apr 6, 2006 | 11:07 AM
ChipN's Avatar
ChipN
I just had AFR 205 heads, a FAST 90 LSx intake with a hand ported LS2 TB installed at DTE and picked-up my car this week. My car is a A4 with stock TC, has QTP Tri-Y headers, and custom grind cam that is very mild (almost no lope), Halltech Stinger, undersize pulleys, Z06 Ti exhaust, and 3.42 gears (supposedly lowers the rwhp/rwtq numbers slightly).
The car is now making 423 rwhp and 391 rwtq (link to dyno charts below). The AFR heads / Fast 90 / LS2 TB added 55.5 rwhp and 34 rwtq with my configuration (probably limited somewhat by my headers).
http://www.comp-soln.com/NewDyno.pdf
Hope that helps.
Old Apr 6, 2006 | 12:24 PM
Darkness's Avatar
Darkness
Wow, this topic is so extenssive that I dont even know where to begin. Start be telling us what you want to do with the car. e.g. Daily driver with some power, street strip with lots of power, all out race setup, etc. Plus tell us how much you want to spend on this project and we'll direct you to a good package.
Old Apr 6, 2006 | 12:30 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Welome to 2006, did you enjoy your sleep?
Old Apr 6, 2006 | 12:41 PM
Darkness's Avatar
Darkness
lol remember that some peeps dont follow these things as a religion like some of us do!
Old Apr 6, 2006 | 03:41 PM
99 vett babycar's Avatar
99 vett babycar
Hope that helps.
just about same combo with Yank SS 3600 see sig for details - you will not regret getting the AFRs.
Old Apr 6, 2006 | 04:32 PM
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
Hope that helps.
Excellent results....Congrats....Thats big power in an auto with that docile a package.
The KEY is consistancy....seems every vendor out there hits a homerun with a few installs, but fewer of them do it alot, and even fewer do it on a regular basis.
The AFR's deliver by achieving above average results (some well above) in practically every single application they are applied to. Seems the handful of slightly disappointing AFR #'s came from shops that decided to port them themselves increasing volume and taking away from the approach we spent almost a year optimizing.
I don't think I have seen a single disappointed customer with an out of the box AFR....They might be a little more money but in the end you get what you paid for and then some. The guys that save the money up front end up spending even more when they decide to go back in a look for the HP they appear to be missing....ALOT of people can relate to that scenario.....trust me on that.
Good luck whichever route you choose to take...
Tony M.
Old Apr 6, 2006 | 06:39 PM
1996man's Avatar
1996man
Im mainly talking about flow numbers ie., cfm on the intake side. for instance about the most you can get out of heads designed for an LT4 motor is about 300-310CFM. I know actual C5R heads are ported and make close to 400cfm. im just curious what cfm most of these aftermarket heads are running.
Old Apr 6, 2006 | 11:06 PM
Darkness's Avatar
Darkness
You can get LS6 heads to flow 330cfm at high lift but then you'll have a huge port and in the end low end tq suffers. What is it that you want to do? All out peak numbers for the race track, get a set of LS6 ported from one of the tuners here on the forum, you want all around power from down low tq to high rpm hp get a set of AFR's. I'd go with 225's, a BIG cam, LT's, FAST 90/90, pulley, electric water pump, a good valve train and make 500rwhp. Wait till the motor blows, for the fun to begin...383, 408, 427, 441...
Old Apr 6, 2006 | 11:15 PM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Two proven vendors on heads would be AFR and ETP.
On large bore motors I prefer the LS7 heads from GM.
Good luck on your project,
CHarlie
Old Apr 7, 2006 | 02:02 AM
1996man's Avatar
1996man
CHarlie
Thanks. I wont be doing anything for a while but im kicking around ideas of a motor swap in my car and going with a heavily bored and stroked C5r motor for lots of NA power
Old Apr 7, 2006 | 04:32 PM
myblackC5's Avatar
myblackC5
Default 400 ft lbs tork!!!!
Hope that helps.
shur would like to know the numbers on that cam. stock idle, all that tork. when the hp numbers, and the tork numbers are that close it makes for a fun car to drive!
Old Apr 7, 2006 | 05:02 PM
1996man's Avatar
1996man
does anyone know what hte stock LS7 heads flow stock? has anyone ported them yet to see what they will flow?
ChipN's Avatar
ChipN
Sort of scary fun at this point since I've only had it back a few days and am not fully used to it yet. The tires break free easily and pretty much any speed (so far) and I find myself underestimating acceleration and going a bit too fast. Not bad problems to have - just need to be a little more careful for a while. But yes, fun.
The cam is a DTE custom grind. The specifications were not disclosed other than 115 LSA. Another guy on the forum put together a spreadsheet between several cars with QTP headers and the torque on my car was +100 rwtq at 2,500 rpm, and stayed a good +30-50 rwtq above the others the rest of the rpm range. It's sort of like secret sauce on a burger. You may not know what's in it but you know that you like it.
To high flow heads
