Rear Fender marker lights
Old Aug 17, 2001 | 11:06 PM
zeeman's Avatar
zeeman
Default Rear Fender marker lights
Needing advice on the easiest route to take to replace the rear side marker lights......Anyone on the Forum ever do this Mod to Amber?
Thanks!!
The Zman....
Old Aug 17, 2001 | 11:18 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
Default Re: Rear Fender marker lights (Zeeman)
Remove outside tailight and reach thru to remove. put old fastners on new markers and carefully cut new threads. much easier install when the threads are precut. take your time. Don't over tighten markers or tailights ,just plastic and can be damaged. Good luck.
Old Aug 17, 2001 | 11:26 PM
zeeman's Avatar
zeeman
Default Re: Rear Fender marker lights (itsonlyairandfuel)
Thanks for the quick reply!! Mucho appreciated! Read on some other Forum,where someone pointed out,removing the rear fender linings,and goin that route? The way you described sounds easy enough for me :crazy:
I will do that as I am replacing the stock lamps for the Euro Taillight assy.
Thanks!
Zman :cheers:
Old Aug 18, 2001 | 10:54 AM
Black Rain's Avatar
Black Rain
Default Re: Rear Fender marker lights ¥Zeeman¤
Not sure about the Hardtop / Z06 antenna mount, but on the Roadster with the Power Antenna you can access the Left side through the taillight assembly, but the antenna is in the way on the Right side, and the liner route is the ONLY way to go :U
Old Aug 18, 2001 | 04:24 PM
zeeman's Avatar
zeeman
Default Re: Rear Fender marker lights ¥Zeeman¤ (Black Rain)
Thanks Greg....
With the Z06 having a fixed mast.....may be possible to go through the tail light lens housing there also.....Thanks for the tip!!
Zman :cheers:
Old Aug 18, 2001 | 08:35 PM
Roger1's Avatar
Roger1
Zeeman.....Did this same mod to my '00 Hardtop. Remove L & R outer taillights and reach thru. Be extremely careful when putting the new nuts on. You can break the plastic post in a heart beat. Going to do the same in a couple of weeks to my '01.
Roger
Old Aug 19, 2001 | 02:19 AM
zeeman's Avatar
zeeman
Default Re: Rear Fender marker lights (Roger1)
Roger....
Thanks for the comeback.....and advice!! All I need now is for 29 more days to elapse,so I can have the Z06 home where it belongs....
Zman
To Rear Fender marker lights
