HELP no AC!
Old Aug 18, 2001 | 11:03 AM
hookedup's Avatar
hookedup
Default HELP no AC!
'92 w/ECC, no codes on ECC except "00" which means no problems, not, compressor doesn't kick in. I'll be checking the fuses and wiring , any other typical areas to look at? I'm not real fond of the ECC anyway, has anyone change over to manual control panel? If so how difficult and what parts are needed besides the panel & cable? I'm heading for Carlisle so I should be able to pick up the parts there, Thanks Dave
Old Aug 18, 2001 | 11:25 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: HELP no AC! (new92racer)
A system that is low on freon will shut down,but should display an "09" code.Simply disconnect the battery to reset.If the compressor starts operating,then you now that it is undercharged.If that is not the case,check all your pressure switches on the low and high pressure lines,as faults with them are common.
Old Aug 18, 2001 | 11:31 PM
hookedup's Avatar
hookedup
Default Re: HELP no AC! (C-5 TECH)
C-5 TECH, thanks for the tips, I don't know how I wound up in the C5 section, Dave :eek:
To HELP no AC!
