Checking Hood Clearance
Old Aug 18, 2001 | 03:15 PM
MDT's Avatar
MDT
Default Checking Hood Clearance
Was wondering if anyone had a simple method for determining the clearance between a selected point on the engine and the hood/hoodliner.
Thanks.
Mark
Old Aug 18, 2001 | 03:44 PM
mozin's Avatar
mozin
Default Re: Checking Hood Clearance (MDT)
Get some kid's play dough but make sure it is the soft kind. Make a little mound and close the hood.
Tom
Old Aug 18, 2001 | 04:06 PM
MDT's Avatar
MDT
Default Re: Checking Hood Clearance (mozin)
Tom
Thanks, Tom.
I knew that was one possibility....just like checking valve to piston clearances. ;)
Thought someone might have an even simpler suggestion.
We'll see if anyone else salutes the question.
See ya.
Mark
Old Aug 18, 2001 | 10:17 PM
Paradigm's Avatar
Paradigm
I can tell you what I did. I used the foam from an insta-pak machine. I filled therbag and closed the hood....waited five minutes and when I opened the hood I had a perfect mold that could be sectioned (if needed) to determine actual clearence.
Old Aug 19, 2001 | 12:38 AM
MDT's Avatar
MDT
Default Re: Checking Hood Clearance ('98 Six Speed)
'98 Six Speed,
Whoa! Now that's slicker than snot on a brass door ****. :D
I think I've figured a way to use a straight edge and a T-square in a fairly simple manner......the complicated part is trying to do a write up. I'll have to give my procedure a check out and if it works easily, I'll attempt to write it up and post.
That's a great idea you offered, '98 Six Speed. :yesnod:
Thanks.
Mark
To Checking Hood Clearance
