Memeory Function Driving Me CRAZY
Old Apr 12, 2006 | 06:30 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Originally Posted by B84RADR
Did you guys know that besides the Memory 1 and Memory 2 buttons, there is a Memory 3 button? There is...press Memory 1 and Memory 2 at the same time to achieve it. If you're wanting to program Memory 3, then hold down both Memory 1 and Memory 2 at the same time for three seconds. Then press both at the same time for recall.
Later,
Shayne
Yup, I use that one for my drag racing settings. Mirrors set WIDE to see losers in the other lane.
Old Apr 12, 2006 | 08:19 PM
Tiger 650's Avatar
Tiger 650
Well, I have tried every suggestion given to me on this post (and I thank all of you for your help ) but the Memory is still wacky. I have retrained the fobs and tried every other suggestion except disconnecting the battery. The reason I have not tried that is because the battery was out recently, because I replaced it, and the memory was not working properly after I installed the new battery.
I don't know what else to do
Can the memory function be disconnected?
Old Apr 12, 2006 | 08:32 PM
doje's Avatar
doje
You can set all the memories to the same setting, then disable the easy entry feature in the DIC. Then the seats should never move.
Old Apr 13, 2006 | 02:28 AM
gpracer1's Avatar
gpracer1
I set my memory 3 to all the way back just like the easy out, for when the car is running and you need to get out for a minute, then hit memory 1 when you get back in....makes it easy to get in and out.
Old Apr 13, 2006 | 09:10 AM
chaase's Avatar
chaase
St. Jude Donor '12
I picked up the car and the memory functions appear to be working normally. I will update when I drive the car again to make sure it "lasts".
Chris
Old Apr 26, 2006 | 01:44 PM
Prtc5Vett's Avatar
Prtc5Vett
Default Seat memory
I have a 1999 vert and also have the problem with my seat memory not working correctly most of the time. Sometimes it goes right to my settings and then other times I have no idea what it is doing, and then other times it won't work at all. If it work sometimes I would not think it could be a flash problem. If so how much did the dealer charge? Sometimes pressing the memory set button works sometimes not.
