Under Carriage Holes
Old Apr 9, 2006 | 09:57 PM
C52002's Avatar
C52002
Default Under Carriage Holes
I am new to the form, and looking for some advise. I purchased a 2002 last year with about 5K, I have since been able to verify the mileage through GM Canada workorders so I am not concerned that I bought some thing other than what I expected.
However when doing an inspection this year after winter storage I discovered two holes in the under carriage. Cearly someone did not know what they were doing and when they put the car on a hoist they punched two holes in the floor board, passenger and driver side, approx 1" x 1/2", looking for suggestions on how best to patch these holes.
Thanks to all from Oakville Ontario Canada,"keep the wave"
Old Apr 10, 2006 | 11:35 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Are the holes all the way through ?
If not, I would go to auto repair shop and have someone weld in patches (heli-arc) as it's aluminium.
Old Apr 10, 2006 | 01:34 PM
jl240z's Avatar
jl240z
Default patches
Be careful How you patch the holes. If I remember correctly the floor pans are a lamination of fiberglass with a balsawood core. If you weld down there even if the outer skin is alum, it will likely burn the core and cause other damage. Perhaps the holes can be filled with an epoxy or something similar. Its where you cant see it anyway and unless it is all the way thru it should be a relatively easy fix. Do some research and wait for some more input from the forum. There are a lot of experienced guys out there. They may know some others with similar problems/fixes. Good luck.
Old Apr 10, 2006 | 08:29 PM
C52002's Avatar
C52002
The holes have not gone all the way through, and you are correct it is a lamination of fiberglass and balsawood. I like the epoxy suggestion, I will watch the forum for any other suggestions.
Thank you for you help.
Old Apr 11, 2006 | 11:41 AM
Ron Dittmer's Avatar
Ron Dittmer
What comes to my mind, assuming the metal has broken through with concern of water soaking the Balsa wood.
Use clear or gray colored silicone caulk, the kind used on house windows. Buy the pure silicone with the 50 year durability. Be sure to clean the surface with windex and let dry before applying the caulk. You can buy that type of window caulk at Lowes, Home Depot, Menards, Builders Square, Ace Hardware etc.
You may need to do it in multiple steps if the hole is too big and without some scrap metal inside the hole to suppor the caulk. Use a putty knife to smooth it out for a nicer look.
If the floor is simply dented without broken metal, just leave it alone. Anything you do will make it look worse.
Old Apr 11, 2006 | 02:01 PM
leaftye's Avatar
leaftye
Would there be another pair of holes towards the rear of the frame too?
Old Apr 11, 2006 | 02:21 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The floor boards on ALL C5's are Sheet Molded Composite (SMC) with a balsa wood core. The floor panel is 1/2" thick in most places (except where the depressions and indents are made for mounting things. The floor pans on the C6 Z06 are carbon fiber with the same balsa wood core. Man that thing is stiff and very light!
What I would do is clean up the edges of ruptured SMC so that they are smooth and clean. Remove any damaged balsa wood core. GM Body shops and even your Local Body shops sells an epoxy mastic for gluing SMC to SMC and SMC to metal (same stuff that mounts the floor panels to the metal cross braces and the body. That is what I would use. It is very thick and will be able to be squeezed in to the void and you can apply some cellophane over the damaged area and then cover it with duct tape to keep it in place until it sets up. When you pull the tape off the cellophane will keep the mastic from sticking to the tape!
Once it sets up, you can sand it flush and smooth. That would be the best and most permanent repair.
Please let us know what you decide to do and how the repair turns out.
Bill C
Old Apr 11, 2006 | 02:55 PM
vette dan's Avatar
vette dan
Vette Dan
If you are talking about holes in the frame on the outside they are the spots for the jacking pucks. From your last post that is what I think you are looking at.
Do you have a pic or draw us a position of these holes.
Old Apr 11, 2006 | 03:48 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Bill C
I used this stuff on my C-4 87 Vert. to replace the rear deck it bonds very well to SMC but even better to metal. In the C-4 there are some steel support brackets I had to grind the old stuff it would not split or chisel off. The stuff I used was made by Ashland Chemical they make several cure rates so be sure you know your open time or it will set up on you before your ready. Mine was set to kick off in 45 minutes that gave us time to position the panel before it set. Any questions about it email me.
Old Apr 12, 2006 | 06:32 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here are some pictures of a display floor panel;
Bill C
To Under Carriage Holes
