Weird DIC message: Remove Key, wait 10 seconds
Old Apr 10, 2006 | 08:41 AM
Pursuit_in_Progress's Avatar
Pursuit_in_Progress
Default Weird DIC message: Remove Key, wait 10 seconds
Like the title says, after filling up my tank at the pump the other day, I got a weird message when I tried to start the car.
"Remove Key, Wait 10 seconds"
I did, and all is well, but why?
Old Apr 10, 2006 | 09:03 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
http://forums.corvetteforum.com/show....php?t=1015483
Old Apr 10, 2006 | 10:24 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
That message usually means that the security system did not read the resistor pellet that is embedded in your key correctly. There are a few things that can cause this.
One is that the contacts on the key are dirty and need to be cleaned. alcohol works well!
The other is that the little contacts in the ignition cylinder are dirty or worn. For the most part, removing the key and reinserting it back in the ignition corrects the problem. If you don't remove the key and reinsert it like the message asks, when you try to move the car, the engine will STALL!!
The security system cuts off the fuel and kills the engine.
Hopefully, it's just a dirty resistor pellet. If you have a second key, give that one a try.
BC
Old Apr 10, 2006 | 11:37 AM
doje's Avatar
doje
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
I find Johnny Walker Blue Label to be the most effective, but some of the cheap guys here will just use rubbing alcohol.
Old Apr 10, 2006 | 01:20 PM
2kbluestreak's Avatar
2kbluestreak
Every time I got that message with my C5 and every time my old C4 (with VATS) wouldn't start it was because I got the key wet.
Old Apr 10, 2006 | 03:04 PM
yellowvette837's Avatar
yellowvette837
St. Jude Donor '03 thru'19
Tampa Events Princess
2015 C6 of Year Finalist
I Believe In The Beer Fairy
This message came up on my DIC this morning.
It has come up before. I just ignore it
To Weird DIC message: Remove Key, wait 10 seconds
