160 thermostat
Old Apr 14, 2006 | 10:31 AM
  #41
corvette Mark's Avatar
corvette Mark
Originally Posted by Yell-01Vette
When I first bought the car, I was holding @ 190 all the time, but lately on long drives home in heavy traffic I've been climbing to 220, even ticked 230 once for just a sec, kind of has me worried.
I'm not super-handy, so I'm not sure about pulling the radiator to clean it, and I'm concerned that it might be a thermo issue, having had that problem before on prior (quite a bit higher mileage) cars. If I decide to replace the thermo, I haven't decided what temp to go with, i'm thinking of adding a blackwing or vararam and a catback system in the not-to-distant future. Any suggestions would be much appreciated, sorry for the hijack.
Oh, and lest I forget the requirement for posting in this thread:
BS-finance-Mizzou (04)
I would like to help you with this question but my flame suit is at the cleaners. For your own safety I would suggest you post a new thread for this question.
my credentials: B.S. artist
Old Apr 14, 2006 | 12:34 PM
  #42
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Wow, you are pull no punches here so I'm going to sit right on the fence and watch. With that said, you have to place some value in what ET is saying. Documentation and testing usually out weighs the gut feelings everytime. I have heard many times people tell me that the C5's dyno higher HP's at lower temps but I wonder how many times the ONLY change was lowering the temps. Often several mods were done between dynos and who know what did what?
The one question I still will never understand is:
Q1 How does a lower stat change the operating temperature? Since the stat does not control high end, changing the low end shouldn't have any affect.
Old Apr 14, 2006 | 12:53 PM
  #43
6Speeder's Avatar
6Speeder
A1. It changes the operating temp because it allows the coolant to continue to flow through the radiator, and loose heat till it gets to the lower temp when the stat closes. This presumes you either change the fan turn on/off temps or are going faster than 35 mph to get air flowing through the radiator. As for your musings about the only change, you're right. But, if you're careful, you can do this, and I have.
Old Apr 14, 2006 | 01:54 PM
  #44
Too-Tall's Avatar
Too-Tall
Originally Posted by TomT
Hell, I didn't know I had one. I thought it was air cooled.
You mean its not???? Doesn't VW own GM....only a matter of time
Old Apr 14, 2006 | 06:02 PM
  #45
Hilander's Avatar
Hilander
I was going to reply but as I am British I could not convert my qualifications haha
Oh and I drive a Ford so guess my opinion might be considered moot.
Old Apr 14, 2006 | 10:24 PM
  #46
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Ok, maybe. But when someone is running say 200-210 with a 190 stat, the stat is fully open. Then when they install a 160 it is also fully open anything over 160. If the system wouldn't come down to 190 with a 190 stat, it isn't going to come down to 160 either.
Old Apr 15, 2006 | 03:00 AM
  #47
RebelVette's Avatar
RebelVette
I think everyone here needs a little Valium...
__________________________________
RebelVette, Pharm.D.
Old Apr 15, 2006 | 03:06 AM
  #48
Joecooool's Avatar
Joecooool
Jax Events Coordinator
CI 3-4-5-6-7-8-9 Veteran
St. Jude Donor '03-'08
John Lingenfelter put one on my Corvette.
Mike Norris put one on my GTO.
Both did it as a standard part of the package I ordered.
Thats all I need to know...
Old Apr 15, 2006 | 06:15 AM
  #49
diviniti's Avatar
diviniti
St. Jude Donor '05
Screw the 160* T-stat, sign me up for the drugs....
Old Apr 15, 2006 | 09:13 AM
  #50
6Speeder's Avatar
6Speeder
The reason they are running 200 to 210 because there is no air flowing through the radiator. Drive faster, or turn the fans on earlier to pull the heat out of the coolant. Stock fans don't turn on till 205 (Stage1) and 220 (Stage 2)
If the system is in good shape, not clogged with leaves and stuff, then it will come down.
Old Apr 15, 2006 | 09:45 AM
  #51
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
More Bullsh|t from a know nothing about this car...
Being involved in the oil life monitor system and the PCM algorythims I can tell you This Guy 6 speeder is again offering his Bull sh|t there is No 205 command or 220 command for fan settings
These are the actual PCM algorythims as written:
For late Models 01-04
The low speed cooling fans are commanded on when the coolant temperature reaches 108°C (226°F). They are turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fans are commanded on when the coolant temperature reaches 113°C (235°F). they are turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fans will be turned on at vehicle speeds less than 56 kPh (35 mph). Fans are turned off above 35 mph.
For early model years:97-00
Low speed fans come on at 219,high speed fans come on at 228,low speed with a/c on...
Both fans have high and low speed capabilities
The Fans cycle on and off with the AC on when the AC head pressure dictates it.
Lowering the fan setting only effect coolant temps below 35 mph.
Old Apr 15, 2006 | 11:18 AM
  #52
6Speeder's Avatar
6Speeder
You need to get a life ET.
The point is his car runs those temps because he is running slower than 35 and/or the fans are at their stock settings. Which I said. As for the 205/220 Vs. 219 etc. I changed them on my Vette 5 years ago. Damm, am I glad. Stock is even worse than I thought.
Old Apr 15, 2006 | 09:31 PM
  #53
VETTING's Avatar
VETTING
Are fan settings infinately adjustable or are there preset parameters to adhere to? I changed to a 160 stat because my tuner (Vette Doctots)changed the fan settings and they seem to run alot longer and frequently. I am new to "vetting" but like to know what makes them go.
Old Apr 15, 2006 | 10:14 PM
  #54
Too-Tall's Avatar
Too-Tall
I think that is the point.....while you are waiting in line at the drag or at a light........it keeps the car cooler.......
Old Apr 15, 2006 | 10:21 PM
  #55
Too-Tall's Avatar
Too-Tall
did you reset your fans...having a faster opening thermostat has nothing to do with how hot your engine gets,,, it just controls how cold it will get...on a cold night your engine will see temps close to 160 F which is very bad for this engine... with a stock 190 stat the coldest your engine will get is 190 F which is good.
once the stat is open be it 160 or 190, heat will rise in the engine just as fast as it did before.... setting your fans to a lower temp will help keep coolant at a lower temp under 35 mph... after 35 mph the fans shut off. with the ac on the fans will cycle on and depending on ac head pressure.
Hey ET............ I checked your profile and you say you HAVE 160 degree stat...............sounds like you are endangering your engine on COLD NIGHTS! Very bad for your engine!!
I think you are the one full of
Old Apr 16, 2006 | 12:07 AM
  #56
geocor2003's Avatar
geocor2003
I saw that too!
Old Apr 16, 2006 | 06:52 AM
  #57
Warp Factor's Avatar
Warp Factor
ET, sometimes things are easier to understand or accept when we have more information.
Can you tell us precisely what what happens and why (bad things) if an engine is run with a 160 thermostat, and do you have results of engine longevity tests with a cooler thermostat versus stock?
To 160 thermostat
Old Apr 16, 2006 | 08:22 AM
  #58
TomT's Avatar
TomT
I just love it.
This ET guy has been writing many long winded diatribes about how 160 degree stats are terrible for YOUR car, but in HIS car he runs a 160 degree stat. Sounds just like a GM engineer, do as I say, not as I do.
I absolutely love it.
This forum is great.
Old Apr 16, 2006 | 09:00 AM
  #59
6Speeder's Avatar
6Speeder
You know et, if you are willing to keep the foul language and attacks off the forum, I'd love to have a civil, rational discussion on the subject. So far, you have mentioned (in passing) the ONLY negative I have seen to a lower temp thermostat, expected oil life on the Corvette's algorythm.
What do you say?
Old Apr 16, 2006 | 09:24 AM
  #60
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
, with the 160 t-stat, and so did ECS. But you guys are right, in ET's profile, he says that he runs a 160 stat, what an AZZHAT
