How to pull codes?
Old Apr 12, 2006 | 04:22 PM
SDotC5Vette's Avatar
SDotC5Vette
Default How to pull codes?
How do you pull the codes on a 98 C5? I completely forgot...thanks
Old Apr 12, 2006 | 04:39 PM
SDotC5Vette
I have some problems with my abs/traction control/and active handling and I need to figure out how to get the codes up so I can see what may be wrong
Old Apr 12, 2006 | 04:51 PM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
Hold down the #4 button and press the #1 button 3 or 4 times this will get you into the code area. It will automatically scroll through any codes. To stop the automatic scroll press reset. buttons 3 and 4 scroll between the different control modules and buttons 1 and 2 scroll back and forth between the actual codes in each module. If you are looking to remove a code or clear it, find the code and then press and hold rest til it disappears. To exit the program, press the e/m button.
Example:
To enter program: hold button 4 press 1 three or four times while holding button 4.
To stop the auto scroll, press reset.
To scroll to the left door module, press the 4 button multiple times til you see it. To manually scrol back through the moduels press the 3 button multiple times.
Once you are in a specific module press 2 multiple times to scroll through individual codes in that module. press 1 button multiple times to scroll back through the same codes.
Press reset to clear the codes in each module. You have to do this for each module to clear all codes.
press e/m to exit!
Old Apr 12, 2006 | 05:01 PM
SDotC5Vette
To How to pull codes?
