PCV catch can question
Old Apr 13, 2006 | 04:42 PM
zeusoftexas's Avatar
zeusoftexas
Default PCV catch can question
Could you use a remote oil filter bracket and a spin on oil filter as a catch can for the PCV system? Check it every once and a while and replace with a new filter when it gets full?
Old Apr 13, 2006 | 07:26 PM
vettenuts's Avatar
vettenuts
That would likely be too restrictive. I have the AMW can, and while it is a lot of money, it is a quality piece that works very well. You can't put too much of a pressure drop in the system or you won't vent correctly.
Old Apr 13, 2006 | 08:35 PM
ALLEGRO's Avatar
ALLEGRO
Too restrictive.
I went with the CH bowl and am amazed at how much there was from the get-go. '03 AE, 18K, no oil usage and still some gets by.
To PCV catch can question
