Launch Technique for A4?
Old Aug 20, 2001 | 09:46 AM
C5NBM's Avatar
C5NBM
Default Launch Technique for A4?
I know this has been discuss many times but did a search and couldn't find anything. Anyone know what is the best launch technique for an A4? Plus, what is the best PSI for the tires when running at the track? TIA!
Old Aug 20, 2001 | 01:31 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Default Re: Launch Technique for A4? (C5NBM)
My method-- staged, traction control set in competition mode ( Active handling on / traction control off) brake torque the car. Left foot on brake pressing on gas to bring rpm up to close to stall speed on converter, takes slop out of driveline. At second yellow release brake and ease on gas to avoid too much wheel spin. Once hooked up hammer it. This is running stock EMT's using 28 lbs pressure. Drag radials or other strip tires need different technique.
Old Aug 20, 2001 | 01:57 PM
Nilla Ice's Avatar
Nilla Ice
Power brake it. Inflate front tires to 40 PSI. I know they are runflats, but it willstill help. Rears to 28.
Tony
Old Aug 20, 2001 | 03:20 PM
C5XTASY's Avatar
C5XTASY
Default Re: Launch Technique for A4? (CHJ In Virginia)
If your car is a 1998-2000 with Generation 1 Active Handling, you'll have to turn off both Traction Control and Active Handling to powerbrake the car. With Generation 1, in Competitive Driving, torque management intervenes when you attempt to powerbrake. The further you depress the accelerator the further down engine power will cycle. Generation 2 Active Handling, as mentioned, will allow you to power brake in Competitive Driving.
Ed
Old Aug 20, 2001 | 10:46 PM
97silverbullet's Avatar
97silverbullet
Default Re: Launch Technique for A4? (C5XTASY)
Turn traction controll off. Brake torque just enough to torque the car up a little. When the lights come down, floor it. I'm running EMTs at 35 psi all around(not that this is a part of my technique, this is just where they are at). I have not done anything with tire pressures. I have never had any wheel spin. :chevy
Old Aug 20, 2001 | 11:32 PM
goldman's Avatar
goldman
Default Re: Launch Technique for A4? (97silverbullet)
How can you "floor it" & not have some tire spin???
Even when I had the 2.73 axle w/EMTs it would spin alot in 1st & a good chirp into 2nd (but still ran mid-13's). With my 3.42 rear, Powerloader, & pilot sports, I'm in the 12's but have even more tire spin!!!
Still working on my launch... but what seems to work best, so far, is launching at about 12-1500, with less than full thottle... anything over about 3/4 throttle seems to get uncontrolable spin. Once the tires hook up, then floor it.
Old Aug 20, 2001 | 11:41 PM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Launch Technique for A4? (goldman)
I had real good 60' times by heating up the Run Flats real good before I staged. Still learning how to launch on the Michelins :( plus I just bought some drag radials but haven't really got to try em out yet.
To Launch Technique for A4?
