What's a Ripper do......really?
Old Aug 20, 2001 | 10:13 AM
bassfisher's Avatar
bassfisher
Default What's a Ripper do......really?
If I take off my Ripper, and change back to stock air intake I can run a lower NCCC class. Problem is I love my Ripper!
But after thinking about it is it really doing anything other than changing the pivot point of the shifter to shorten the travel of the shift **** between gears? I can do the same thing by cutting down the stock shifter, (which appears to be legal, but need to check).
What am I overlooking? Comments please.
Old Aug 20, 2001 | 11:22 AM
PeterK's Avatar
PeterK
St. Jude Donor '12
2012 Election Contest Winner
Default Re: What's a Ripper do......really? (bassfisher)
Well, if you ever decide to do it. I'll buy the ripper from you.
Old Aug 20, 2001 | 11:37 AM
Paul R's Avatar
Paul R
Cruise-In I Veteran
Cruise-In II Veteran
The ripper also has a much stronger set of springs in it, allowing the shifter to return to center much more cleanly than stock. This is what allows you to make that 2 -> 3 shift better, the centering spring brings the shifter over to center more effectively.
Old Aug 20, 2001 | 12:31 PM
CP's Avatar
CP
Default Re: What's a Ripper do......really? (Paul R)
It's also used to build up the muscles in your right arm. :lol:
It's also used to keep females from driving your Vette!!!!! :cheers:
Old Aug 20, 2001 | 01:08 PM
bassfisher's Avatar
bassfisher
Default Re: What's a Ripper do......really? (CP)
""It's also used to keep females from driving your Vette!!!!! ""
My wife loves the Ripper too so it doesn't work with all of them!
The stiffer springs makes sense, I guess I don't remember how sloppy the stock shifter was. But again with the shorter lever arm it will seem stiffer.
Anything else?
[Modified by bassfisher, 11:09 AM 8/20/2001]
Old Aug 20, 2001 | 01:12 PM
BruceF's Avatar
BruceF
It's the relocation of the pivot point that makes the biggest difference. While cutting down the shift arm will help a bit, you will still feel a big difference between that and the Ripper shifter.
To What's a Ripper do......really?
