Need help with proper sizing for tires..
Old Apr 19, 2006 | 10:50 AM
Whitelightningvette1's Avatar
Default Need help with proper sizing for tires..
the rims are 19"x9.5" fronts and 20"x10.5" backs it's a 2000 c5 coupe. Thank you in advance
Old Apr 19, 2006 | 10:55 AM
VetteDrmr's Avatar
VetteDrmr
Go to tirerack's website. They can give you the specs you need for whatever tires you want to buy, as well as recommended widths for your wheel sizes. Assuming you're just wanting to cruise the streets, make sure the tires you get have the same diameter as the stockers (can't remember right off the top of my head, but you can check any 245/45/R17 and 275/40/R18 tire for the numbers).
HTH, and have a good one,
Mike
Old Apr 19, 2006 | 11:21 AM
Thank you for the info.They say the proper height would be 245/35/19 and 285/30/20 but say I wanted to go just a tad higher and wider is it possible without their being a problem with clearance?
Old Apr 19, 2006 | 11:28 AM
VetteDrmr's Avatar
VetteDrmr
245 is the stock width for the fronts, which are 8.5" wide wheels. I'd think 245s would be a bit narrow for 9.5"; you can comfortably go up to 275s without rubbing (that's what I use racing).
Same with the rears. Stock Z06 wheels are 10.5" wide with 295 rubber; again I think 285s would be too narrow. Try to see if you can get some 295-305 tires.
Now, taller I don't understand. It's doable, but you're going to have to get the PCM reprogrammed for the different tire diameter, especially if your coupe is an A4. Personally I'd stay as close to the stock diameter as possible.
Mike
Old Apr 19, 2006 | 11:39 AM
To explain the taller part I just do want to have to lower the car to much and if you will excuse the term I just don't want it to look to getto with the sidewalls being to low profile.
To Need help with proper sizing for tires..
