Help clunk sound from right left wheel area.
Ted
[Modified by BigTed, 11:58 AM 8/20/2001]
It wouldn't hurt to check all the fittings on the suspension and torque 'em down to spec.
I suspect halfshaft joints, not swaybar bolts, since I haven't had any suspension stuff off.
Anybody had this noise and had it investigatedf and fixed?
Has anybody else had this problem and had it fixed? If so, please provide details. Thanks
This is what to do:
Do not jack car or remove rear wheel. Apply bark brake and put in 1st gear. (Hopefully your brake works. If not, you'll probably need a helper to apply brakes)
Remove lug nut covers and center cap.
You will see a large threaded shaft (the axle) and a large nut. This nut is torqued to 118 ft-lbs, according to the service manual.
You will need a 1 5/16 deep socket and a fairly large breaker bar. I was using 3/4 drive equipment. You may have a hard time finding this large of a socket in 1/2 inch drive. And, it does have to be deep, because the end of the axle (the threaded portion) sticks out about an inch past the nut.
Put some oil on the threads (mine were quite rusty), have your helper hold the brake, and break the nut loose and remove. It's not really very tight...only a little bit more than wheel lug torque. But the initial "break loose" does require some leveragae. Be carful not to gouge the side of your car with the breaker bar!!
Do not worry about removing this nut. The wheel will NOT come flying off and you will not damage anything.
You will probably see some dusty rust in the cavity after you remove the nut. Blow the dust out if you can, but it's not a big deal.
Oh yeah, tell your helper to relax. I'll bet his/her leg is tired by now!:cry
Using the red wand on your WD-40, stick the wand in to the spline area and give it some squirts in a few places. Excess will run out so have a grease rag handy. Give it a few minutes and do it again to try to inject as much lube in as you can. Rock the car in gear (brake off, dummy!) to work the lube into the splines. It won't go far into that spline....it has to creep in, so spray and rock, spray and rock. That's where the noise is coming from, so work it in.
Put a little bit of engine oil in there if you have a squirter, just for good measure. Don't go wild....just a little. I used 3-in-1. Not the thickest oil in the world, but more lube-y than WD.
Your clunk/knock should be gone.
Put some oil on the threads, and run the nut in. It doesn't spin on....you'll have to wrench it on after the first few threads engage.
Have helper apply brake, and tighten to 118 ft-lbs or, in my case with no 3/4 inch torqe wrench, to goodendamntight specifications. ;)
Finish up with the center cap and lug covers and you're done.
No more clunk! Hurray!
I'm gonna do the other side now, just for preventive maintenance.
I was thinking that a good quality antisieze spray might be better, but getting it worked into the spline might be difficult. I didn't have any, so I went with the WD to experiment. The WD probably won't last forever, which is why I think a little shot of heavier oil, after the penetrating spray, might keep things quiet longer.
Total time--15 minutes, assuming you have that big socket laying around.
I'd posted this very same topic a few months ago, until now, no one had responded. Mine is the same way...first pull out of the driveway in first gear (when the wheels drop off the curb). So I've read the remedy, could do myself, but my question is what causes it, and is there any chance of long term damage?
But yeah, I wonder how long WD will last on this high load component.
As for your noise.........is it because the wheels drop off the curb, or because of engine torque applied to the splines when you engage clutch or give it some gas (auto)? If it's due to suspension motion (as opposed to driveline loading), it might not be this dry spline problem.
My noise got so bad that in first gear, idling around in a parking lot, it would knock as you gave it a little gas AND when you backed off the gas. KNOCK.....knock....KNOCK...knock......wh o's there?
