1998, ICP message "SERV TIRE MON SYS"
Old Aug 22, 2001 | 02:03 PM
CarlB's Avatar
CarlB
Default 1998, ICP message "SERV TIRE MON SYS"
Rear tires replaced recently and getting "SRV TIRE MON SYS" message at
start. No tire pressure indication for any of the tires. If a broken sensor/s shouldn't the fronts show pressure. If the wheels were re-install on the wrong side would this cause the message? Do I need to run the re-learn ?
Any words of wisdom are appreciated.
Old Aug 22, 2001 | 02:41 PM
4THTOY's Avatar
4THTOY
Default Re: 1998, ICP message "SERV TIRE MON SYS" (CarlB)
If the tires were changed, you most likly have to go through the relearn policy. Happened to me when I changed tires
Ira
Old Aug 22, 2001 | 02:46 PM
CarlB's Avatar
CarlB
Default Re: 1998, ICP message "SERV TIRE MON SYS" (3rdtoy)
Thanks 3rdToy, will try the re-learn.
Old Aug 22, 2001 | 03:51 PM
CarlB's Avatar
CarlB
3rdToy,
Re-training worked, all is well. Thanks to you and the guys who posted the
"how to". Forum members are great. Hope I can return the favor.
Old Aug 22, 2001 | 04:09 PM
Chopper Larry's Avatar
Chopper Larry
It has happened to me also, but should NOT, if they do it right; I think the wheels should not be switched. My last tire swap, things continued to work fine!
To 1998, ICP message "SERV TIRE MON SYS"
