Upper Ball Joint Replacement
Old Apr 21, 2006 | 05:36 PM
VA 98 VETTE's Avatar
VA 98 VETTE
Default Upper Ball Joint Replacement
Can someone tell me how to remove the upper ball joint from the spindle? Thanks.
Old Apr 21, 2006 | 06:24 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
You will need to get a ball joint separater and a big hammer.
Take the nut loose and then you will slide it in there.. hammer it til it come apart. You will have to be careful not to tear the boot, if you are replacing it the new one will come with a new boot. The tools to do this can be had at any local autoparts store very cheap.
Hope that helps.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Apr 21, 2006 | 07:59 PM
VA 98 VETTE
Hope that helps.
BlownZ06,
Thanks man...but I know how to get it seperated. What I don't know is how to get the old one out of the spindle assy. I'm use to seeing 3 bolts on the top of the ball joint that hold it in the assy. This has what looks like a pressed on cover.
Old Apr 21, 2006 | 09:16 PM
BLOWNZO6's Avatar
BLOWNZO6
BlownZ06,
LOL.. sorry... Just saw your post and was like.. OH that one is an easy one...
Looked it up in the service manual.. it presses out.
Old Apr 22, 2006 | 01:23 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
BlownZ06,
You need to have a ball joint press to get it out. You can pick a set up for at a local auto store or see if your local auto zone has a free loaner set.
May I ask where you got your upper ball joints from. To my knowledge you can only but the lower ball joints (Moog). I tried to buy the uppers but could not locate a supplier. To my understanding you have to buy the entire spindle assembly to get the upper ball joint.
Old Apr 22, 2006 | 03:44 AM
VA 98 VETTE
I have yet to locate a set, either. It appears you are correct.
Old Apr 22, 2006 | 07:20 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
figure about $110/120 for a new spindle shipped; fyi-the front left/rear right are the same spindle and vice versa
Old Apr 22, 2006 | 09:28 AM
VA 98 VETTE
Thanks!
To Upper Ball Joint Replacement
