Trailer Hitch installation
Old Apr 21, 2006 | 09:39 PM
SouthernSon's Avatar
SouthernSon
Default Trailer Hitch installation
I just installed the draw-tite hitch on the Z and I must say that every thing is pretty much straight forward. There was a trick or two involved that I will pass on to anyone else entertaining a hitch that may be of help. First, the 1" drill bit can be bought at Lowe's for around $10. It looks like a door **** hole saw yet is also for metal. It works very well. Second, in order to get the smaller stove bolts and their flange into the existing holes I used a small piece of SS wire wrapped around the bolt and then passing through the flange. One simply pushes the bolt into the frame followed by the flange and then fish the bolt back through.
